Tool changes with gang tool lathe
BillB
Post by BillB »
Is there a way to eliminate tool change position move to (tool change location) in Intercon for use with gang tool lathe. So the after tool 1 we just go through to the next machining operation so the program runs unattended? What do I need to do to make that work?
Re: Tool changes with gang tool lathe
When changing from front to rear tools, manually insert x and z moves (F1 Line) in Intercon to move the next tool to the proper side of the work.
BillB
Post by BillB »
What if you set the tool change position to 0,0 Would that force the control just run the program without any pause or prompt. Or would it go to home position for fool change?
The Lathe version of Intercon does not have a tool change position.
If you mean the G28 return point, X0 Z0 there means go to machine zero.
The move to the G28 position for each tool change is selectable on the Intercon Setup menu. Just set "Suppress G28 for tool change" to "Yes".
While you are at it, you can tell Intercon to leave the spindle and coolant running during tool changes.
You can suppress the wait-for-cycle-start in either of two ways:
1) Don't change tool numbers, just change offsets (e.g. T01, T02, T03)
2) Make a "cnctch.mac" file that is blank, or contains only a comment.
BillB
Post by BillB »
cncsnw wrote: Sat Jan 08, 2022 2:28 am The Lathe version of Intercon does not have a tool change position.
Im not fiding "Suppress G28 for tool change" Is it in the Intercon window where you program the part? OR are you referring to the config setup pages Could you provide a screenshot?
As Marc posted, the Suppress G28 is on the Intercon Setup menu. Inside Intercon press F9 Setup.
Page 80 of the Lathe Operator's Manual has a picture. If you supress the return to G28, YOU will be responsible for moving EACH AND EVERY tool clear of the work before a tool change.
BillB
Post by BillB »
Guys would this document still be relevant for V12 lathe?
https://www.centroidcnc.com/dealersuppo ... ds/128.pdf
Pretty much.
On a Windows CNC11/CNC12 system, the tool-change macro file is c:\cnct\cnctch.mac.
The cnctch.mac file should not contain an M99. It should just be blank, or contain only a comment such as "; gang tooling -- no action required".
I am not certain you even need to set Parameter 6 = 1. You could try it both ways.
BillB
Post by BillB »
cncsnw wrote: Mon Jan 10, 2022 12:13 pm Pretty much.
Ok thanks : )
