Drives that accept AC.
- Plasma CNC Controller: Yes
Re: Drives that accept AC.
No brake...martyscncgarage wrote: ↑Fri Dec 31, 2021 1:29 pm https://www.automationtechnologiesinc.c ... 50w-220vac
I am form Germay, and like you I like to by from a local dealer, better service and in 2 days at my shop.
But things here are a bit more expensive than in the USA.
Import costs here + ~8% Tax and 19% VAT
Thanks for the link.
Regards
The one that I linked is from Leadshine. Look for it there.suntravel wrote: ↑Fri Dec 31, 2021 2:41 pmNo brake...martyscncgarage wrote: ↑Fri Dec 31, 2021 1:29 pm https://www.automationtechnologiesinc.c ... 50w-220vac
Regards
Jep, I know, quite common on the german low end market.
Most shops here have JMC and Leadshine, JMC is preferred nowadays if the pocket is not deep enough for Kollmorgen, Mitsubishi or Fanuc
Regards
Regards
I use Leadshine easy servo 220v 3ph closed loop steppers more than 8 years. I run very heavy woodworking steel router 5x12 feet . No gearboxes, no backlash. Amazing performance, very good speed, very high torque. Also very quiet and low working temperature. Very reliable drive. Also Acorn works super friendly with Leadshine ES-DH2306 drives. I will never go to Servo and gearboxes anymore.
They would be a good choice for the Klopp mill here asked for too....IvanVelchev wrote: ↑Fri Dec 31, 2021 10:51 pm I use Leadshine easy servo 220v 3ph closed loop steppers more than 8 years. I run very heavy woodworking steel router 5x12 feet . No gearboxes, no backlash. Amazing performance, very good speed, very high torque. Also very quiet and low working temperature. Very reliable drive. Also Acorn works super friendly with Leadshine ES-DH2306 drives. I will never go to Servo and gearboxes anymore.
Those ES-DH2306 drives are the ones I have picked to use. I think coupled with the Acorn it will be an easy conversion.IvanVelchev wrote: ↑Fri Dec 31, 2021 10:51 pm I use Leadshine easy servo 220v 3ph closed loop steppers more than 8 years. I run very heavy woodworking steel router 5x12 feet . No gearboxes, no backlash. Amazing performance, very good speed, very high torque. Also very quiet and low working temperature. Very reliable drive. Also Acorn works super friendly with Leadshine ES-DH2306 drives. I will never go to Servo and gearboxes anymore.
Where are you sourcing the larger Leadshine Easy Servo Drive from....Black Forest wrote: ↑Sat Jan 01, 2022 4:44 amThose ES-DH2306 drives are the ones I have picked to use. I think coupled with the Acorn it will be an easy conversion.IvanVelchev wrote: ↑Fri Dec 31, 2021 10:51 pm I use Leadshine easy servo 220v 3ph closed loop steppers more than 8 years. I run very heavy woodworking steel router 5x12 feet . No gearboxes, no backlash. Amazing performance, very good speed, very high torque. Also very quiet and low working temperature. Very reliable drive. Also Acorn works super friendly with Leadshine ES-DH2306 drives. I will never go to Servo and gearboxes anymore.
There are several places that I have looked. One is, https://www.damencnc.commartyscncgarage wrote: ↑Sat Jan 01, 2022 10:06 amWhere are you sourcing the larger Leadshine Easy Servo Drive from....Black Forest wrote: ↑Sat Jan 01, 2022 4:44 amThose ES-DH2306 drives are the ones I have picked to use. I think coupled with the Acorn it will be an easy conversion.IvanVelchev wrote: ↑Fri Dec 31, 2021 10:51 pm I use Leadshine easy servo 220v 3ph closed loop steppers more than 8 years. I run very heavy woodworking steel router 5x12 feet . No gearboxes, no backlash. Amazing performance, very good speed, very high torque. Also very quiet and low working temperature. Very reliable drive. Also Acorn works super friendly with Leadshine ES-DH2306 drives. I will never go to Servo and gearboxes anymore.
There are several places that sell here in Germany that are Chinese companies with inventory here in Germany. I am a little skeptical as to the authenticity to the drives and motors being actual Leadshine and not knock-offs. The Damen company seems to be quite reliable and also sells Delta products. I will probably buy from them even though they are more expensive. Reliability is important that is why I am going with a Centroid product. Centroids support is the best in the industry. Just look at you Marty. Hangover and all on New Years day you are on here helping people!
a good CNC seller in Germany for Leadshine:
https://www.sorotec.de/shop/CNC-Steueru ... steme-385/
