Is there a way to set up WMPG macro to 10% rapids and 100% feedoverride?
rk9268vc
Post by rk9268vc »
I want to hit a button to go to 10% speed for risky moves, and a button to jump back to 100% feeds
the feed dial on WMPG is fine and all, but I have to take my eyes of the prize to dial it back in to 100% feeds watching the control panel. no bueno
thanks
Re: Is there a way to set up WMPG macro to 10% rapids and 100% feedoverride?
You can edit your PLC program to set the desired values in "KbOverride_W" in response to whatever keypresses you want to use.
For example, in the Feedrate Override section:
IF MPGMacro1_M THEN KBOverride_W = 10
IF MPGMacro2_M THEN KBOverride_W = 100
You will want to make sure you do not have CNC macro files set up for whichever keys you choose to use. You might want to comment out the lines that set SV_SYS_MACRO in response to those keys.
There is only one override, and it will apply either to both rapids and feedrate moves; or to feedrate moves only. There is no way to have an override value that slows down rapids without slowing down feedrate moves.
