Unable to setup homing <answered>
- CNC Control System Serial Number: 0035FF98CA2D-0813215079
Hello,
I have been trying to setup homing and thought I had everything setup correctly.
https://photos.app.goo.gl/y7ven8Ht7mevHm326
The settings do not save on the wizard either.
I have been trying to hit cycle start in order to find automatically the home position and no axis move.
Any suggestions on what might be wrong? DId I miss any steps?
Re: Unable to setup homing
Gonna need more information, a report, screen shots of your other wizard screens....
viewtopic.php?f=60&t=1043
How are your proxy switches set in the Inputs page?
Scott
My apologies Scott, trying to get used to properly post a technical question here.
Please see the attachments, is the Inputs page in the wizard? I have included a screenshot of that as well.
I have to tell you as well that I have loaded one of the gcode files and did a dry run and the cnc moved without an issue.
- report_0035FF98CA2D-0813215079_2021-12-03_22-42-39.zip
- (652.79 KiB) Downloaded 64 times
Your have not configured any home switches. Are they wired? In the screen with all the LED's displayed, do they inputs toggle from red to green and back when you trip the switches? Which LED's toggle with which switches? for example does #1 trip when you toggle x-, #2 with X+ etc...
What page(s) do I set the home switches?centroidsupport wrote: ↑Sat Dec 04, 2021 10:07 am Your have not configured any home switches. Are they wired? In the screen with all the LED's displayed, do they inputs toggle from red to green and back when you trip the switches? Which LED's toggle with which switches? for example does #1 trip when you toggle x-, #2 with X+ etc...
The video below shows an older version of the software.
I do have switches installed and I will trip them and get back to you on this.
I'll get back to you when I have all the information I need.
E415F6F70BC3-0318203049
Tony
You need to provide all information requested by Support including uploading a new REPORT.ZIP (On home page F7 Utility then F7 Create Report). Save to desktop and then upload the ZIP file (i.e.without extracting).
Hope this helps
Nigel
Nigel
Attaching the report now
- report_0035FF98CA2D-0813215079_2021-12-04_13-04-24.zip
- (639.56 KiB) Downloaded 63 times
It appears that you have not set up anything in the Wizard for inputs/outputs and possibly axis configuration. We have no idea what your machine needs as far as configuration for drive type, type of prox switches (NC/NO), and axes config, you'll need to provide such information. When you chose a drive type, you need to "load" it and follow the prompt from the Wizard (sometimes you need to scroll up/down side/side to see the "Load Drive" buttons). After that you need to work your way through the Wizard and set your inputs/outputs, axis config accordingly and then chose to "write" those settings or none of it will be saved.
Your current homing file (created by the Wizard) is just a simple home, meaning that when prompted to hit cycle start, it just sets home at it's current position. Setting the inputs correctly for your switches and the settings in "Homing" will then change that routine.
Scott
