Hicup DC servo motor kp ki kd
TD-4242
CNC Control System Serial Number: KI04039
Post by TD-4242 »
I have old Yaskawa DC motors:
UGHMED-06 GG1XX
        cont.  inst.
kW      0.51 - 2.57
kg-cm   50   - 250
rpm     1000 - 1000
Volts   113
Amps    6.5  - 32
with the defautl:
Kp 1.0
Ki 0.004
kd 3.0
it works but makes a lot of noise while holding.
I'm going to try manual tuning but was just wondering if there's maybe a good starting point other than the default that may help me out.
https://photos.app.goo.gl/Psw7ungT3tukJoit6
Re: Hi Cup DC servo motor kp ki kd
Try:
Kp = 0.6
Ki = 0.001
Kd = 1.2
TD-4242
Post by TD-4242 »
While playing around I was finally able to get it so it was only making a very small amount of noise at:
Kp 0.3
ki 0.0008
kd 0.3
This was after a lot of trial and error. Not sure if this is good or bad though, as this is the first time I've ever tried doing something like this.
TD-4242
Post by TD-4242 »
seems like these numbers aren't great either as it is still a bit shaky finding zero.
I evidently missed where you posted a Report, or told us what type of control system you are using.
I am guessing that you settled on an Allin1DC, and are therefore using torque-mode control (the only kind that Allin1DC does).
If instead you opted to use an Oak control and the old Yaskawa drives, in velocity mode, then the approach may be very different.
There is no guarantee that you will find a satisfactory middle ground between too noisy/jittery, and not responsive enough. Since these motors are generally unexplored territory, you probably know as much about tuning them as anyone.
TD-4242
Post by TD-4242 »
Yeah, sorry about that I was just asking if anyone had any known numbers for these specific drives.
This is an Allin1dc. I'll run a report and upload it.
TD-4242
Post by TD-4242 »
This is just the initial bench testing to insure that I can get things to work before doing the cabinet layout and taring down the old Acroloc.
Here is the bench test environment:
Here's a video of the noises this drive is making although youtube compressed and washed out the audio:
polaraligned
Post by polaraligned »
You will never be able to tune them correctly on the bench. Mount them up and then run the tuning routines. Even then it can be a bit hard for the inexperienced, but post any problems and someone should be able to give you guidance.
TD-4242
Post by TD-4242 »
Thanks, working slowly through it I didn't want to tare down the current machine until I had a little more knowledge on the processes. I'll take the fact that I can move the motors as my current success and move forward. Have a bunch of stuff on the way for me to start working on cabinet layout.
Bill, your video seems reasonable for a motor on the bench with no load.
Its good you can control the motor at this point.
If you get in jamb, I have 3 Centroid 29 in-lb. motors.
P.S. Always get in the habit of generating and posting a fresh report when you need help.
