Hello,
I made CAD + CAM. Using a CNC router and would like to make with step 100mm 20 pcs same product from 12mm playwood sheet.
Is it possible to make massproduction in in Centroid UI or i need to make CAM with full layout?
massproduction
Re: massproduction
Manual page 164 explains the repeat function.
Regards
Regards
Re: massproduction
Thanks Uwe,
I am a new one here.
Can you also send me a link of this manual?
Lauri
Lauri
Re: massproduction
If you are using offline CAD/CAM instead of the Intercon conversational, then Intercon's Repeat function does not apply. You will either need to do a shift and repeat via G code (see G52 and M98 in chapters 12 and 13, for example); or you will have to find out how your particular CAD/CAM software provides repeats.
Re: massproduction
it seems that i need to make a fresh install and add intercon.
Does it lost all my machine settings if i will make new install
I use Fusion 360 but it will be nice when my CNC operator can change near the machine how many pcs he will mill.
Re: massproduction
Intercon is installed standard. You should find it under F5/CAM from the main screen.
