major headache int tool offsets
hi
im having a bit of a nightmare and need some help .
I have a slant bed lathe with a quick change tool post
ive set all the od tools as per manual and YouTube and all is good .
t1 is ref tool od
and rear approach
I bored a hole and measured it 32.53 mm
when I set the id tools eg t9
I set ref x to 32.53 and touched off t9 , zeroed the original x offset in the table ,measure tool , measure x .save
the tool table populated with offset 65.94mm . the difference between t1 and t9 is only a couple of mm
if I then mdi t909 and press start ,the x position says -32.53mm instead of 32.53 mm
so im obviously doing something wrong or have a wrong setting somewhere on my cnc12 lathe software.
if any can see a glaringly obvious mistake ive made any help will be appreciated
thanks
t1 is ref tool od
and rear approach
thanks
Re: major headache int tool offsets
hi, to start off a support request, always post a fresh report.zip along with the g code program you are working with.
hi
zip file attached , no g code attached as im just trying to set tool table offsets
I guess I have some setting wrong as it is only for internal tools that I have a problem .
when t909 offset called with the tool actually in a position of say 32.53 hole diameter ,dro is showing -32.53
have you followed the steps in the Lathe operator manual? the section on setting up tool offsets is pretty good. page 57
and review back to basics with this video on external dia tool setting as well.
viewtopic.php?p=11479#p11479
When I read his first post, it certainly looks to me like he is following the procedure described on page 57 of the Lathe operator's manual.
Keith: do you see any discrepancies, when you re-read his first post, with particular attention to the values in his screen shots?
Chessie: if you change the designation from "ID" to "OD", then measure that same tool in the same place with the same reference diameter entered, do you get the same (wrong) result? Or do you get a correct measurement?
cncsnw,cncsnw wrote: ↑Fri Oct 22, 2021 4:48 pm When I read his first post, it certainly looks to me like he is following the procedure described on page 57 of the Lathe operator's manual.
I have looked at everything also and it looks correct. I am thinking there might be an issue in the software with being in metric. I know he is from UK and is using metric.
Chessie,
After trying what cncsnw suggested try changing tool orient to Front orient with X diam. at 32.53 There was an issue in earlier software version in imperial where you had to call an ID tool as Front orient instead of the ID orient when measuring tools. This might not have got corrected correctly for metric. As a note You are 4 hours ahead of us being in UK.
Dana
You will probably have to set Machine Parameter 163 to a value of 1, in order to be able to change individual tools between Front and Back approach.cnc_smith wrote:After trying what cncsnw suggested try changing tool orient to Front orient with X diam. at 32.53 There was an issue in earlier software version in imperial where you had to call an ID tool as Front orient instead of the ID orient when measuring tools.
thanks everyone
I did follow the manual and watched the video ,od tools perfect id tools is where it falls down . ive had this issue from day one but originally manually input the id tool offset to get around it . it maybe worth changing fig 5 on p60.
I changed the id to od as asked and it works fine ,its a good work around I just had to change it back after the measurement was populated.
I set parameter 163 to 1 and tried it again changing it to front and it didn't work it still populated the offset with 66mm.
So im presuming this is a glitch with the metric version of the software that can maybe be fixed on a future update .
We are at this time on day light saving time so it is 4 hours. The first of November we go to standard time then 5 hours.
Dana
