Axis slaving on Oak/DMM
repauli1
Post by repauli1 »
Am I reading the manual correctly that you need to change the wiring on slaved axis to reverse the rotation? Why not just check the REV checkbox ?
I am using the Dyn4 1.3kw servo motors.
ashesman
Re: Axis slaving on Oak/DMM
Post by ashesman »
Should be able to change direction of the axis in software. It works fine for non slaved axis. Why not give it a go and see what happens? If it doesn't work then swapping wires is easy enough, just swap the pins in the axis connector for axis output A and /A and feedback A and /A.
