SOLVED: invalid value, F360, Swissi post
Fueler1
CNC Control System Serial Number: 101981
Post by Fueler1 »
Fusion 360. Post Swissi 005
Up til now no real issue with 360 or Swissi post.
The latest Fusion 360 update changed the post window a bit. Gray and boring.
That is neither here or there.
I am getting an invalid value on line 13 showing E54.
Looks like that should be G54
yes, no, maybe?
I will run it by the 360 board just to cover the bases.
Fueler1
Re: invalid value, F360, Swissi post
Post by Fueler1 »
OK, I have tried several different posts with the same results.
I then opened up some previous successful projects and that E54 does not show. G54 has taken it's place
SOOO, it's something weird with this file.
Found it. It's a 360 gramming error.
lavrgs
Re: SOLVED: invalid value, F360, Swissi post
Post by lavrgs »
I'm having the same problem but only on one file. Not sure what a gramming error is but I'd like to fix it 9-)
You can select work coordinate system #1 with either of two codes:
E1
or
G54
An "E54" code would be a request for work coordinate system #54, which does not exist.
See page 221 in the operator's manual:
https://www.centroidcnc.com/centroid_di ... -v4.20.pdf
