Thanks Marty,martyscncgarage wrote: ↑Thu Aug 26, 2021 10:24 am
There are 3 groupings of wires
1st group of 3 wires is power to the turret motor So is the turret motor 3 phase??
2nd group of 2 wires is to power the logic switches for position of the turret Not following this. please clarify
3rd group of 4 wires represent a signal line for each position So have you taken the cover off the turret or have a schematic that shows the circuitry? Do you have optical sensors?
Pictures are worth a thousand words. Please post pictures of the turret, and with its cover off. Post a link to any videos or other pictures of this machine operating. Need a better understanding of how your turret works.
Gray logic usually uses sensors that are blocked by windows, based on the tool position. There is a truth table. ONs and OFFs based on which tool is in position.
Take the time to download the ATC package and look at the lathe instructions:
viewforum.php?f=63
Look for ATC overview and download it.
I have downloaded the ATC package and was reading through it last night. I believe that the 1motor setup looks appropriate.
1. It is a 240V turret motor (L1,L2,N1)
2. the 2 wires are 24V+ and gnd. These provide power to the position switches. I am not sure if they are optical or mechanical as I haven't disassembled the turret to that degree.
3. I have a schematic of how it was connected to the prior Chinese control. I used that to help identify the wire alignment.
Attached is a picture and a video https://youtu.be/m_38xJjF_P8 that I hope clarifies things a bit more
Bob
