Show me your Custom VCP's!
- CNC Control System Serial Number: 3549
Here's mine for my hobby mill. Still a work in progress.
Would love to see a VCP similar to the Estlcam controller. Muli-speed jogging buttons very simple layout, very easy to use, very easy to teach non-technichal people to use.
Unfortunately way past my skill set to generate
can you share an image of it?johnsattuk wrote: ↑Wed Jul 07, 2021 11:21 am Would love to see a VCP similar to the Estlcam controller. Muli-speed jogging buttons very simple layout, very easy to use, very easy to teach non-technichal people to use.
- CNC Control System Serial Number: A901038
Hello all.
I am in the process of converting my machine over to the allin1.
I did my bench testing and setup already and I am now mounting and wiring the control.
Before I broke it down from bench testing, I figured I would setup the control panel which was fairly easy to understand from keiths video.
But here is where I need some help.
There are buttons for set x 0 and set z 0 but not a set y 0. There is a set xy 0 but not a y by itself.
I did try and copy the xml from the z , renamed it and changed the button with inkscape, but it did not work.
I do see that some of you guys have a set y 0 button and I would like to know how you did it.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
Just assign Macro M26 to the button you want.I do see that some of you guys have a set y 0 button and I would like to know how you did it.
So " M26 /Y " should do it.
Jack
read up in the operator M and G code chapters....m26 is setting the machine coordinate system., typically a Y0 button on the VCP will set a Work Coordinate position.
the CNC12 operator manual, vcp manual and macro manual are all located in the All Acorn documentation link here... they contain everything you need to create a macro and a custom button.
Yeah, I used "G92 Y0" inside of the mfunc56 macro for my VCP M56 button to set Y0. I had since updated the button graphic to say Set Y0. Same with the M55 button for X and M57 button for Z.typically a Y0 button on the VCP will set a Work Coordinate position.
- CNC Control System Serial Number: 0479B7ABE506-0318203048
Just added two new zeroing buttons as I added a laser to my z axis which is not in-line with the spindle center. When I hit the Laser X 0 or Laser Y 0, it sets 0 with the offset of the laser (IE it sets zero at spindle center where the laser dot is).
Kind of hack but the laser cost me like $15 and the VCP change took like 20 minutes.
(sorry the pic is rotated... it isn't on my computer and when I click to enlarge it isn't rotated either)
Love the buttons and it looks great. Just curious why 2 buttons? I have mine setup like this, I press the "Laser Zero" button on the VCP and the laser comes on and the Z axis moves to the proper height for sharp focus of the laser crosshair on the spoil board. Then I created a message that pops up on the screen that says "Jog laser cross hairs to desired part X0 Y0 position. Press CYCLE START to set X0 Y0". I simply jog the laser to part zero and when I press cycle start the laser shuts off and the X and Y move the programmed offset for my machine to part zero and the Z axis moves to the home position at the top. Just curious why one axis at a time.RichMaple wrote: ↑Sun Sep 19, 2021 3:05 pm Just added two new zeroing buttons as I added a laser to my z axis which is not in-line with the spindle center. When I hit the Laser X 0 or Laser Y 0, it sets 0 with the offset of the laser (IE it sets zero at spindle center where the laser dot is).
