Probe Jog Parameters
Hamm3rs18
Post by Hamm3rs18 »
I am not seeing the menu to change the jog speeds when a probe is plugged in.
Manual says I need "Proper PLC support" but what specifically does that require?
Parameter 153 is set to 1.000 //Probe Protection feature enabled
Any help is appreciated.
Thanks.
Re: Probe Jog Parameters
Use the Acorn Wizard to set the fast and slow probing rates, refer to the Probe setup guide here.
https://www.centroidcnc.com/centroid_di ... _setup.pdf
Hamm3rs18
Post by Hamm3rs18 »
These setting do not affect the Jog speed when probe is plugged in.
I want to limit the MPG JOG speed when probe is plugged in..
Thanks.
Hamm3rs18 wrote: Wed Jun 23, 2021 12:22 pm These setting do not affect the Jog speed when probe is plugged in.
Thanks.
would take custom PLC program to do that. I suggest getting in the habit of using the Slow Jog mode in conjunction with the feedrate overide and x1 and x10 incremental when using incremental jogging.
