Doesnt work with MACH3?
adamfromscotland
Post by adamfromscotland »
HI
Just got my new board
2 x quick questions
doesnt work with MACH3?
And the free software can only work with 3 x axis?
I want to slave my 3rd axis to my 4th axis ?
Upnorth
Re: Doesnt work with MACH3?
Post by Upnorth »
I can answer the first question. The acorn has it's own software. Mach 3 is of no use with an acorn board.
Second question answer is you can do hardware paring with the free version. You need pro or ultimate to do software pairing.
adamfromscotland
Thanks for the replies you guys
What the difference between hardware and software pairing?
on mach3 i can slave my Y Axis with the Slave A axis
If i cant do that im going to return the boards
please let me know
adam
Unless i get the pro version for free im going to return my boards sadly
Not worth trying to get more money from me for simply slaving my Y Axis to the second a AXIS ON MY CNC ROUTER BUILD
adamfromscotland
misleading website for sure
your website needs updated
says whats included in the acorn package then to add the 4th axis i need to pay $160 more to slave the 4th axis
i thought the pro version was included and shouldnt be shown in the included list
its a nice board but im going to have to return it
Did you not read the last post? You can do hardware pairing with the "free" version of the software. You can wire the the Y axis with the A axis by wiring them to the same axis. The "free" version of the software is limited just like the "free" version of crappy, old Mach3. If you want to run larger CNC files you need to buy the pro version license of the software (just like Mach3). The "free" version of Mach3 is limited as is the "free" version of CNC12 from Centroid.
The website is not misleading at all, it's explained very clearly what you get for your money. If you have questions please ask.
The machines that I have retrofit have all had Mach3 on them and there is no comparison between the two. Mach3 is hobby grade at best and CNC12 is light years ahead of it. If you want a hardware AND software package (that's constantly improved) from the same company with outstanding support buy the Acorn. If you want to cobble together one companies hardware with another companies software that hasn't been updated since, well, the stone age (and never will be) keep running Mach3. :mrgreen:
You are correct. Returning it and sticking with Mach3 is your best bet.
tblough wrote: Thu Jun 10, 2021 7:19 am You are correct. Returning it and sticking with Mach3 is your best bet.
OMG, I nearly spit out my morning coffee reading that one, thanks for the laugh. :mrgreen:
Gary Campbell
Post by Gary Campbell »
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
MACH3 is trash compared to Acorn. It will be the best $160 you ever spent.
