Drive fault 9031 on ACORN CNC12
Re: Drive fault 9031 on ACORN CNC12
Try this, go into the Wizard and remove the drive enable from the inputs.
Then restart everything and see if your motor will turn or if the drive faults. If the drive faults then there may be something wrong with the drive/motor.
Check all your connections too.
Iflyb777
CNC Control System Serial Number: 0035FF98C2BC-0421214705
Post by Iflyb777 »
ok did as you requested motor doesn't move or i got no faults driver and motor get very hot
I have put call into John no answer
Drive did not fault? And did not move?
Are you using the Acorn +5vdc power supply to +PUL and +DIR and connecting -PUL and -DIR to Acorn Power Supply COM?
Iflyb777
Post by Iflyb777 »
acorn 5vdc power supply to +PUL +DIR + ENA
-PUL to ST1 on acorn
-DIR to DR1 on acorn
-ENA to EN1 on acorn
+ALM to IN5 on acorn
-ALM to COM on acorn
Iflyb777
Post by Iflyb777 »
John is going send me new motor
thanks again for your help
let you know how it all work out I may need help down road
Larry
PS great u-tube i learn lot from them
Glad to hear. I hope it's not the drive....
By the way, it's ACORN like the nut not ACRON 😁
Iflyb777
Post by Iflyb777 »
thanks
typing to fast
i am also going to weight and hookup using DB 25 break out to acorn
