First: will restoring report.zip restore all settings to new acorn board or do I have to go through any of bench tests like spindle bench test and other settings all over again?
Second: Will I have to do restore report.zip if only BBG is replaced for new one or the settings are stored on acorn card
Restoring report.zip to new acorn board (Resolved)
Re: Restoring report.zip to new acorn board
1) Yes, IF the same version of software is installed
2) Yes AND you will need Centroid to generate a new license
Thanks… So no need to set anything when restoring either on new bbg or new acornGary Campbell wrote: ↑Sat May 15, 2021 10:29 am 1) Yes, IF the same version of software is installed
Follow the videos for a new install
All done.. replaced new bbg and everything works as it should
