Acorn Router Pro CNC software 4.46v & FreeCAD 0.19v
lloxley016
CNC Control System Serial Number: SYSTEM ID 0035FF8E0F46-0904203691 MPU12 System
Post by lloxley016 »
Hello, eveyone
I.m using FreeCAD 0.19v :?:
After creating my project It gives me several different format to export my project. So wondering which would be the correct format To export so the Acorn can understand the g-code, *.cnc it’s not in the option to export. What other format can I use to export the project For centroid Acorn Router Pro 4.46v
I will appreciate any help..
Pics of my rebuild CNC-6040Z :D :D
CNC 6040Z /Acorn CNC Controller/Stepperonline Nema 34/Cl86Y :D
lavrgs
Re: Acorn Router Pro CNC software 4.46v & FreeCAD 0.19v
Post by lavrgs »
*.nc? What are the options?
lloxley016
the two picture show all the list of the different format. to export
Is the FreeCAD software CAD and CAM software like fusion 360? If there is no CAM portion with the software you can’t export any file type to load into Acorn. You need something to convert your drawing into g code. Those extensions in your pics are CAD extensions not g code extensions.
Your only choice there is Autodesk DXF 2D and use the Intercon DXF Import feature to generat ethe G-code from the 2D geometry. As Shawn pointed out, FreeCAD is CAD software. It creates geometry and the export formats are just other geometry formats. You need something another piece of software that converts the geometry into machining instructions - a CAM package.
Fusion360 includes a 2.5D CAM package in entry level package. There are other CAM packages out there including the more expensive ones like MasterCAM, SolidCAM, EdgeCAM. In most cases these are CAM packages only and require a separate CAD package like FreeCAD or SolidWorks.
lloxley016 wrote: Tue May 04, 2021 7:17 pm Hello, eveyone
CAD does the drawing, then you have to process it through a CAM program like Sheetcam, CAMBam and others.
CAD does not create the G code. CAM does.
If you want CAD/CAM for routers, look at the Vectric line of products.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
You could also check out DeskProto CAM package which has a basic free licence as well as Hobby/Educational and Commercial versions. I haven't used this myself as I have no need but you have multiple CAD import options and a specific Centroid G-Code generator.
Hope this helps
Hope this helps
Nigel
lloxley016
Thanks, all your fast reply guys.
i'm very happy that i went with Centriod Acorn Products., Your support is outstanding.
I'm reviewing all three CAD/CAM.
FreeCAD
VCarve Desktop
DeskProto V7
What i like about FreeCAD it's not because it free, But all the cool feature & tools, And potenial of program it to your content.
Vcarve Desktop it's other one., it has all G-code format for different CNC controller., Including Centriod Acorrn.
