Circles look like potatoes
JunkfoodGuy
CNC Control System Serial Number: 4484
Post by JunkfoodGuy »
Hey everyone, doing an upgrade on an Avid 4896 pro to Clearpath SDSK/Acorn/C86ACCP.
Yesterday was a nema 34 machine and worked fine. Now my 1" circles look like potatoes.
Re-ran x-axis tuning. Cleared up all the windows settings and got rid of some resends. Everything is mechanically sound - same as it was yesterday. Cutting HDPE pockets at .15" DOC with a brand new Onsrud 1/2" bit. Nothing crazy. Straight cuts are fine. Tried smoothing, no change.
Could this be accel and decel?
Report is attached.
report_402E71D1309E-0310214484_2021-05-04_19-16-40.zip
(632.29 KiB) Downloaded 74 times
Re: Circles look like potatoes
still seems like a lot of resend errors..
review this post...
viewtopic.php?f=61&t=1451
(1) 05-04-2021 17:17:18 407 Z+ limit (#50001) tripped
(1) 05-04-2021 17:17:38 407 Y- limit (#50003) tripped
(1) 05-04-2021 17:17:41 407 X- limit (#50002) tripped
(1) 05-04-2021 17:17:59 Tool change: T1 Center Drill
(4) 05-04-2021 17:18:19 944 MPU requested resend # 164
(4) 05-04-2021 17:18:19 946 PC resending # 4373
(4) 05-04-2021 17:18:20 944 MPU requested resend # 165
(4) 05-04-2021 17:18:20 946 PC resending # 4377
(4) 05-04-2021 17:18:20 946 PC resending # 4391
(4) 05-04-2021 17:18:20 946 PC resending # 4395
(4) 05-04-2021 17:18:20 946 PC resending # 4402
(4) 05-04-2021 17:18:20 946 PC resending # 4414
(4) 05-04-2021 17:18:20 944 MPU requested resend # 166
(4) 05-04-2021 17:18:20 946 PC resending # 4475
(4) 05-04-2021 17:18:20 944 MPU requested resend # 167
(4) 05-04-2021 17:18:20 946 PC resending # 4480
(4) 05-04-2021 17:18:31 944 MPU requested resend # 168
(4) 05-04-2021 17:18:31 944 MPU requested resend # 169
(4) 05-04-2021 17:18:31 946 PC resending # 4515
(4) 05-04-2021 17:18:31 946 PC resending # 4532
(4) 05-04-2021 17:18:38 944 MPU requested resend # 170
(4) 05-04-2021 17:18:38 946 PC resending # 4544
(4) 05-04-2021 17:18:46 944 MPU requested resend # 171
(4) 05-04-2021 17:18:46 946 PC resending # 4575
(4) 05-04-2021 17:18:46 946 PC resending # 4588
(4) 05-04-2021 17:19:05 944 MPU requested resend # 172
(4) 05-04-2021 17:19:05 946 PC resending # 4595
(4) 05-04-2021 17:19:27 944 MPU requested resend # 173
(4) 05-04-2021 17:19:27 946 PC resending # 4609
(4) 05-04-2021 17:19:35 944 MPU requested resend # 174
(4) 05-04-2021 17:19:35 946 PC resending # 4612
(4) 05-04-2021 17:19:35 946 PC resending # 4632
(4) 05-04-2021 17:19:38 944 MPU requested resend # 175
(4) 05-04-2021 17:19:38 946 PC resending # 4648
(4) 05-04-2021 17:19:50 944 MPU requested resend # 176
(4) 05-04-2021 17:19:50 946 PC resending # 4652
(4) 05-04-2021 17:19:51 944 MPU requested resend # 177
(4) 05-04-2021 17:19:51 946 PC resending # 4660
(4) 05-04-2021 17:19:52 946 PC resending # 4677
(4) 05-04-2021 17:19:57 944 MPU requested resend # 178
(4) 05-04-2021 17:19:57 946 PC resending # 4681
(4) 05-04-2021 17:19:57 944 MPU requested resend # 179
(4) 05-04-2021 17:19:57 946 PC resending # 4687
(4) 05-04-2021 17:20:06 944 MPU requested resend # 180
(4) 05-04-2021 17:20:06 946 PC resending # 4690
(4) 05-04-2021 17:20:06 944 MPU requested resend # 181
(4) 05-04-2021 17:20:06 946 PC resending # 4707
(4) 05-04-2021 17:20:07 944 MPU requested resend # 182
(4) 05-04-2021 17:20:07 946 PC resending # 4719
(4) 05-04-2021 17:20:11 944 MPU requested resend # 183
(4) 05-04-2021 17:20:11 946 PC resending # 4731
(4) 05-04-2021 17:20:12 944 MPU requested resend # 184
(4) 05-04-2021 17:20:12 946 PC resending # 4738
(4) 05-04-2021 17:20:17 944 MPU requested resend # 185
(4) 05-04-2021 17:20:17 946 PC resending # 4749
(4) 05-04-2021 17:20:18 944 MPU requested resend # 186
(4) 05-04-2021 17:20:18 946 PC resending # 4754
(4) 05-04-2021 17:20:23 944 MPU requested resend # 187
(4) 05-04-2021 17:20:23 946 PC resending # 4757
(4) 05-04-2021 17:20:39 944 MPU requested resend # 188
(4) 05-04-2021 17:20:39 946 PC resending # 4777
(4) 05-04-2021 17:20:39 946 PC resending # 4779
(4) 05-04-2021 17:20:43 944 MPU requested resend # 189
(4) 05-04-2021 17:20:43 946 PC resending # 4782
(4) 05-04-2021 17:20:47 944 MPU requested resend # 190
(4) 05-04-2021 17:20:48 946 PC resending # 4784
(4) 05-04-2021 17:20:49 944 MPU requested resend # 191
(4) 05-04-2021 17:20:49 946 PC resending # 4789
(4) 05-04-2021 17:20:59 944 MPU requested resend # 192
(4) 05-04-2021 17:20:59 946 PC resending # 4806
(1) 05-04-2021 17:21:40 407 Z+ limit (#50001) tripped
(1) 05-04-2021 17:21:47 407 Y- limit (#50003) tripped
(4) 05-04-2021 17:21:48 944 MPU requested resend # 193
(4) 05-04-2021 17:21:49 946 PC resending # 4808
(1) 05-04-2021 17:21:58 407 X- limit (#50002) tripped
(4) 05-04-2021 17:22:07 9033 Reset Initiated, Press Reset to Clear
(1) 05-04-2021 17:22:13 204 Exiting CNC...Normal Exit (66)
(1) 05-04-2021 17:56:43 199 CNC Started
(4) 05-04-2021 17:56:48 944 MPU requested resend # 16
(4) 05-04-2021 17:56:48 946 PC resending # 853
(1) 05-04-2021 17:56:49 CNC12 Acorn Router v4.64
(4) 05-04-2021 17:56:49 9033 Reset Initiated, Press Reset to Clear
(4) 05-04-2021 17:56:58 4032 Reset Cleared
(1) 05-04-2021 17:57:21 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 05-04-2021 17:59:57 204 Exiting CNC...Normal Exit (66)
(1) 05-04-2021 18:58:36 199 CNC Started
(1) 05-04-2021 18:58:41 CNC12 Acorn Router v4.64
(4) 05-04-2021 18:58:42 9033 Reset Initiated, Press Reset to Clear
(4) 05-04-2021 18:58:47 4032 Reset Cleared
(1) 05-04-2021 18:59:02 407 Z+ limit (#50001) tripped
(1) 05-04-2021 18:59:05 407 Y- limit (#50003) tripped
(1) 05-04-2021 18:59:07 407 X- limit (#50002) tripped
(1) 05-04-2021 18:59:53 Tool change: T1 Center Drill
(4) 05-04-2021 19:00:02 9033 Reset Initiated, Press Reset to Clear
(4) 05-04-2021 19:00:16 4032 Reset Cleared
(1) 05-04-2021 19:00:50 407 Z+ limit (#50001) tripped
(1) 05-04-2021 19:00:58 407 Y- limit (#50003) tripped
(1) 05-04-2021 19:01:04 407 X- limit (#50002) tripped
(1) 05-04-2021 19:01:45 Tool change: T1 Center Drill
(1) 05-04-2021 19:08:04 407 Z+ limit (#50001) tripped
(1) 05-04-2021 19:08:16 407 Y- limit (#50003) tripped
(1) 05-04-2021 19:08:36 407 X- limit (#50002) tripped
(4) 05-04-2021 19:08:52 9033 Reset Initiated, Press Reset to Clear
(4) 05-04-2021 19:15:08 4032 Reset Cleared
(1) 05-04-2021 19:16:18 407 X- limit (#50002) tripped
(1) 05-04-2021 19:16:40 Creating report...
JunkfoodGuy
Yeah, that was earlier today. Last run (pics) had zero.
You can see that in your post at (1) 05-04-2021 18:58:36 199 CNC Started.
Still potatoes.
post the g code program that was used to make those potatoes.
JunkfoodGuy
here you go. Vcarve Pro, default centroid PP
Your post processor is outputting mostly lines with a few arcs thrown in here an there; smoothing might make a difference. Something like this should be only arcs and 1/100 the size of the file you posted. For a test, create a circle pocket in Intercon and see what that produces on the mill.
OMG, that g code file is over 10 MB, for potatoes? There would have to be 10,000 of them on a sheet to warrant a 10 MB file. Something is certainly wrong with that file. Are you by chance using "curve fit" on the shapes in Vcarve? Post a copy of the Vcarve file also please. I bet if you go into node editing you'll see a problem with the file.
JunkfoodGuy wrote: Wed May 05, 2021 1:28 am here you go. Vcarve Pro, default centroid PP
Why did you remove the G code file?
I would use Intercon to create a test file. Use the Pocket function, don't clean out
Post a FRESH report please.
How did you clean up the PC/MPU Resend errors?
JunkfoodGuy
Yeah, lots of circles. They have a ramp too.
I have seen some improvement by re-running the x axis auto tune and copying that to the Y axis. I feel the Y is where my issue remains.
Circles looking much better but will go out of round if I push past 100% feedrate. I'm going to run a full 4x8 sheet and check the results.
ill post a report after that is done.
To cleanup the errors, I went through your video and knocked out everything that I had not touched when I set it up for Mach a while back. Its a xeon, 32gb machine, running fine now.
