Jog button in VCP sticks on
jumps4
CNC Control System Serial Number: 38d2697ca033-0611180974 mpu12
Re: Jog button in VCP sticks on
Post by jumps4 »
I did what you said to do and I'm testing now
Steve
No Brains, No Headaches...
even so that is not the proper way to have the drive configured, makes no sense to have two identical drives set up differently.
i am stepping you thru what i would do to solve your issue, humor me and i'll continue to help you out.
i have several more things in mind to check, but before we go there we need to make sure basic stuff is sorted properly, do you agree?
Steve,
I too downloaded and installed your Report on my bench test unit with a drive and stepper.
I tried like heck to recreate what it is doing for you. I could not replicate your issue.
Keith is right, go in the Advanced tab and uncheck that inversion on Z and go into the Axis Configuration page and change the direction there under direction reversal. DO that first and retest the issue on Z. Post a fresh report.
I also noted a couple other things but you should make that simple correction, retest to see if you can recreate the problem, and post a fresh report, and we'll go from there.
We're trying to make simple suggestions for you to try.
jumps4
Post by jumps4 »
the problem still exists on both axis
if your trying to replicate this you will have to try a long time and maybe click at different rates to get it to happen and if it does and you clicked again you caused it to stop moving. you have to watch close before clicking again. it always happen when moving in close before going to incremental steps. I'm trying to get close enough to not click 50 increments to move into location for tool measurement. by the time I realize it stuck it is crashing into the part.
Steve
this report is from after changing the settings in wizard
report_38D2697CA033-0611180974_2021-05-03_16-40-25.zip
(926.46 KiB) Downloaded 95 times
jumps4
Post by jumps4 »
I forgot to shut down and restart acorn and re-power the board after changes I rebooted everything now and will retest
the report I sent was after the reboot so it should include the changes.
Steve
can you post a photo of the dip switch settings on the drive? or better yet psot a bunch of photos of the machine and the control system on a google photo album and post the link here.
what was the version of cnc12 did you update from that was originally used to configure the turret (custom plc program) with that you had running satisfactorily?
cnckeith wrote: Mon May 03, 2021 4:59 pm what was the version of cnc12 did you update from that was originally used to configure the turret (custom plc program) with that you had running satisfactorily?
Keith, it looks like 4.18 from his last report file in the archive dated Reported Generated: Thu Oct 3 14:27:57 2019
jumps4
Post by jumps4 »
I had typed the problem was still there before I realized I had not restarted Acorn
after the restart I have not made it happen again. so we may have it...
I'm out of time today but I will be testing tomorrow morning
Marty what other things did you notice?
Steve
jumps4
Post by jumps4 »
The turret and Acorn are working perfect and are very accurate to within .0002 making multiple identical parts.
This is the only problem I have left and I did switch from v4:18 to v4:64.
this was happening when I first installed Acorn before windows updates and before i updated to v4:18, before I ever had a turret. I did have the touch screen then but it is disconnected and no driver installed now. The Shuttlexpress is uninstalled also.
here is the build thread in Hobby-machinist.com :
https://www.hobby-machinist.com/threads ... ers.73280/
here is the build thread here:
https://www.centroidcncforum.com/viewto ... ilit=build
turret build thread here:
https://www.centroidcncforum.com/viewto ... lit=turret
the arduino software controller program and controls that Acorn commands to change tools:
https://forum.arduino.cc/t/cnc-person-n ... son/613918
Controller dip switch settings:
