Jog button in VCP sticks on
jumps4
CNC Control System Serial Number: 38d2697ca033-0611180974 mpu12
Re: Jog button in VCP sticks on <resolved>
Post by jumps4 »
This is the thread I started and I did not mark it resolved.
I have used HP brand of mouse and tried more than one.
In the spring I get really busy but since I see others noticing this issue I will try to get back to this soon.
I will post a report next time I test.
Steve
No Brains, No Headaches...
jumps4 wrote: Fri Apr 30, 2021 10:00 am This is the thread I started and I did not mark it resolved.
Steve
Sounds good Steve...
jumps4
Post by jumps4 »
I don't know how this thread got marked resolved but I have not been able to locate the cause of this problem.
I have tried different mouse, no touchscreen, no shuttlexpress, no windows updates helped
I have changed left mouse select button from double click to single click and the arrow move key will still hang if you repeatedly click it.
To get this to happen I just make short clicks of the z- arrow on the screen like I'm nudging close before switching to increment mode for fine adjustment
It does not happen every time but repeated clicking will cause the button to stay on and run the axis into the part.
I have run out of ideas to fix this. I'm going to try to find a PS/2 mouse and see if that works.
Steve
report_38D2697CA033-0611180974_2021-05-03_13-23-01.zip
(934.49 KiB) Downloaded 87 times
jumps4
Post by jumps4 »
Added note
I have noticed if you click the arrow key when it is stuck on and moving it will stop
so if you are going to try to replicate this you must make sure it has moved and stopped or hung up still moving before pressing button again or you will cancel it without knowing. Be positioned away from everything if you try this. This will happen on fast jog also.
Steve
jumps4
Post by jumps4 »
Here is a video of what happens
Steve
Thanks for the video. I saw the white box around Z- indicating a key press. But your cursor was still over the button. What happens when you just move the cursor off the button? Is it still stuck?
jumps4
Post by jumps4 »
I went back and retested
It does not matter where the cursor is once it sticks. I can move it off and it will continue to move.
Steve
jumps4
Post by jumps4 »
also when I move off the white box is no longer around the button but it is still moving
Hi, what kind of motors and drives are installed on this machine?
i loaded the report.zip on my machine and it does not exhibit the same behavior.
i've seen drives not setup correctly (wired and or parameters) act like this.
I noticed you have Z axis Direction inverted in the Advanced Axis configuration menu of the Wizard. why?
jumps4
Post by jumps4 »
closed loop nema 23 hybrid servo drives with HBS860H drivers
