Acorn burned down < strand of hookup wire on board>.
LenelyWolf
Re: Acorn burned down
Post by LenelyWolf »
martyscncgarage wrote: Sat May 01, 2021 10:36 am You can disconnect everything except Acorn power and Ethernet cable and do a basic bench test.
Hopefully your PC ethernet port wasn't damaged as well
It looks like it work
https://share.icloud.com/photos/0WP-sNa ... h_-_Raunds
https://www.dropbox.com/s/60zrik7vhmdc8 ... 4.mov?dl=0
Lucky.
Start connecting only inputs and test again.
Then connect the axis drives
Test
Then connect outputs
Test
Before you connect the spindle drive, is it a typical Lenze VFD?
Post link to the manual and how you have it wired up to Acorn
LenelyWolf
martyscncgarage wrote: Sat May 01, 2021 12:20 pm Lucky.
Test
Test
Everything works apart from spindle..... still trying to set it up. I can’t get through spindle bench test but I will create new question for that. It is Lenze 534
Manual is here
http://www.lenze.org.ua/pdf/530_Speed_c ... 202_EN.pdf
And I have pin no 7 connected to com on acorn and pin no 8 connected to vout
Re: Acorn burned down < strand of hookup wire on board>.
i would buy a new BBG and swap it out.
So, your Lenze drive is a DC spindle drive.
DO you know if it has built in SIGNAL Isolation?
It is not a standard VFD.
IF your Acorn will no longer pass the spindle bench test, then my guess is that you blew the Spindle Analog Output on Acorn.
Please explain with a sketch how you wired Acorn to the Lenze drive.
LenelyWolf
cnckeith wrote: Sat May 01, 2021 2:30 pm i would buy a new BBG and swap it out.
Yep.. I will do that.. even that the board works which I’m really surprised
LenelyWolf wrote: Sat May 01, 2021 3:01 pm
Also take a picture of the connections in the Lenze drive
LenelyWolf
martyscncgarage wrote: Sat May 01, 2021 2:54 pm So, your Lenze drive is a DC spindle drive.
I really have no idea if that lenze drive has signal isolation. Acorn already passed spindle bench test.. i had one setting wrongly entered. The lenze is connected with acorn with input NO 7 to com on acorn and input NO 8 to vout on acorn so it should work. I actually tested the lenze by connecting 3v battery to that 7 and 8 inputs and it worked
Are you saying now your Acorn passed the spindle benchtest after the "fire works" ?
LenelyWolf
martyscncgarage wrote: Sat May 01, 2021 3:10 pm Are you saying now your Acorn passed the spindle benchtest after the "fire works" ?
Yes it did... I’m surprised as well. I had just one setting in setup wizard entered wrongly so therefore I get max 3 volts out of it..
