Heidenhain ROD 426 encoder compatibility (Resolved)
LenelyWolf
Post by LenelyWolf »
Can anyone tell me if this encoder will be compatible with acorn board or will I need any additional hardwares?
https://www.atechauthority.com/pdf/Rota ... DZJI#page=
Re: Heidenhain ROD 426 encoder compatibility
It should work just fine.
Key items are that it operates on 5VDC and produces a quadrature square wave.
When Heidenhain says an output is "TTL" and shows a square wave, it is always a differential signal, as required by Centroid.
LenelyWolf
cncsnw wrote: Wed Apr 14, 2021 2:03 pm It should work just fine.
Thanks... that is a good news for me 🙂
fyi..for general Acorn encoder reference ..more info on the subject is here. viewtopic.php?f=63&t=921
LenelyWolf
cnckeith wrote: Wed Apr 14, 2021 2:51 pm fyi..for general Acorn encoder reference ..more info on the subject is here. viewtopic.php?f=63&t=921
Thank you... i think I will have to create another question about wiring because wiring in heidenain documentation is not very clear to me. I will try to figure it out on my own but if I fail I will have to come back
Plasma CNC Controller: Yes
LenelyWolf wrote: Wed Apr 14, 2021 2:59 pm
You need the encoder color code chart which tells you which color wire is which function so you can wire the DB9 connector
LenelyWolf
martyscncgarage wrote: Thu Apr 15, 2021 10:23 am
I’ve got it but like I said it is unclear to me.. acorn pin letters are different to heidenhain color code plus I’ve got 12 wires coming out of the encoder and only 9 pins on db9. obviously I’m not an electrician🤷‍♂️
Ua1=A
Ua2=B
Ua0=Z
martyscncgarage wrote: Thu Apr 15, 2021 11:06 am Ua1=A
Ua2=B
Ua0=Z
Up-5vc
PLEASE provide the colors you have...that would sure help......
LenelyWolf
martyscncgarage wrote: Thu Apr 15, 2021 11:07 am
Ua2=B
Ua0=Z
Up-5vc
There is a picture of of the cable with all cable colors. Thanks for this info but still not unclear. Should I connect together brown/green and blue together for +5v white/green and white together to gnd? If so what about those two extra violet and yellow wire?
