If I don't have a tool change the feedrate overide works as it should but if it goes through a tool change it stops responding . I have reinstalled cnc12 thinking I corrupted a file but that didn't work .
Feedrate overide stops working after a tool change (Resolved)
- report_F045DA76BCBE-1108181316_2021-04-12_11-37-54.zip
- (1.09 MiB) Downloaded 83 times
Re: Feedrate overide stops working after a tool change
post the offending g code
Here they are sorry I missed them
- 1015 geneva cam 1 peice.nc
- (53.39 KiB) Downloaded 74 times
- 1001.nc
- (96.44 KiB) Downloaded 76 times
which one has the issue?
are you using m108/9 in the program or any macros or sub programs?
13.37 M108 - Enable Override Controls
M108 re-enables the feedrate override and/or spindle speed override controls if they were disabled with
M109. A parameter of ”1” indicates the feedrate override; ”2” indicates the spindle speed override.
Example:
M109/1/2 ; disables feedrate and spindle speed overrides
M108/1 ; re-enables feedrate override
M108/2 ; re-enables spindle speed override
13.38 M109 - Disable Override Controls
M109 disables the feedrate override and/or spindle speed override controls. It may be used before tapping
with G85 to assure that the machine runs at the programmed feedrate and spindle speed. It is not
necessary to specify M109 with G74 or G84; those cycles automatically disable and re-enable the override
controls. M109 cannot be used in MDI mode.
Example:
M3 S500 ; start spindle in clockwise direction, at 500 rpm
F27.78 ; set feedrate for 18 pitch tap
M109/1/2 ; disable feedrate and spindle speed overrides
G85 X0 Y0 R.1 Z-.5 ; tap a hole
M108/1/2 ; re-enable overrides
Example:
Example:
Both have the issue all my programs now have the issue . I found an m109 that should have been m108 error in my m6 macro and corrected it but that did not correct it . Here are all my macros I am using
M56 resets the atc after an e stop
M53 send an error message if I forget to reset the atc after an estop and ends program
M10 and 11 are used when a tool that is not in the carousel is called in a program
- mfunc10.mac
- (1.8 KiB) Downloaded 83 times
- mfunc11.mac
- (1.31 KiB) Downloaded 72 times
- mfunc53.mac
- (1.32 KiB) Downloaded 93 times
- mfunc56.mac
- (1.04 KiB) Downloaded 78 times
- mfunc6.mac
- (24.55 KiB) Downloaded 76 times
For got 2 macros carousel in and out
51 is carousel in
52 carousel out
51 is carousel in
52 carousel out
- mfunc52.mac
- (869 Bytes) Downloaded 71 times
- mfunc51.mac
- (692 Bytes) Downloaded 79 times
Ok I got it working by moving m108 before the code that sets the tool # in spindel in the m6 macro.
WInston,
Is your ATC working? You have another thread going about issues with your ATC.
You should really try and keep everything together in one build thread.
If your ATC is working correctly great. If it is not, you should get the ATC issues ironed out before moving forward with running programs.
Yes it’s working as far as know never ran one be for . this issue I thought had to do with the other program .Some times you have to run a program to find problems . Like I have said I am not a programmer I barely know g code nothing like in the atc macro. I am sorry if I am causing problems.martyscncgarage wrote: ↑Tue Apr 13, 2021 10:44 amWInston,
