913 ERROR
usinart
913 ERROR
Post by usinart »
Hello
I receive an error message 913 but I would like to know why?
Here is my program and a report.
I want to make a room with 5 other wcs, but nothing wants to open.
Do you have any idea on this.
thank you
Alain :roll:
g54 to g59 #1.nc
(10.24 KiB) Downloaded 79 times
report_E415F6F138CC-1119204064_2021-04-04_18-07-17.zip
(628.28 KiB) Downloaded 66 times
Sword
Re: 913 ERROR
Post by Sword »
No hashtags allowed in the file name, it's not twitter.
Scott
usinart
Re: 913 ERROR
Post by usinart »
Thank you that corrected the error.
 here is another error that I do not understand 907 with an x which exceeds the limits.
 when I look at the graph of cnc12 I see a gap between the 3rd piece (g56) and the 4th (g57). ?
https://photos.app.goo.gl/6mGMbHs4NJ2BuE1N6
Re: 913 ERROR
From your report file:
Axis    Origin    Origin    Origin    Origin    Origin    Origin
        #1(G54)   #2(G55)   #3(G56)   #4(G57)   #5(G58)   #6(G59)
 X      4.56303   10.94388   17.32472  -14.57997  -20.96097  -27.34197
 Y     83.13407   83.13407   83.13407   83.13407   83.13407   83.13407
 Z     -9.79691   -9.79691   -9.79691   -9.79691   -9.79691   -9.79691
When you set your part zeros, did you mean for G57 to be to the left of G54, G55 and G56?
If not, you need to set the G57 part zero position where you want it.
The "907 X axis travel exceeded" message is telling you that, to run your job the way you have it set up, the control would have to go outside the machine's travel envelope.
usinart
Re: 913 ERROR
Post by usinart »
my g 54 and the home piece are those furthest to the left in the assembly.
Why the g57 would be the starting point of the work.
In my cam I give g54 the starting point and then 6 other locations in total to do with the maximum of 6 g of location that cnc12 allows me.
thank you
alain
