Milling Issue
- CNC Control System Serial Number: 78047383DD52-0131191593
Re: Milling Issue
Can you recommend some drives that are compatible with my steppers?
Re: Milling Issue
Re: Milling Issue
For some reason the drive you linked requires minimum +50VDC so you would have to up your power supply, but don't exceed the voltage I mentioned based on the calculation.
The other I linked from CNC4PC.COM appears to be fine from 24VDC-110VDC
http://www.americanmotiontech.com/uploa ... 860E_m.pdf
Contact your vendor with your stepper motor cut sheet.
Re: Milling Issue
You have drives that run at a max 75KHz. The next lower available frequency that the Acorn can generate is 40KHz.
Re: Milling Issue
Hi Marty,
I purchased 3 DM860E stepper drivers that handle up to 200khz pulse rate, It looks like the pulse/dir wiring is the same as in the schematic ACORN_rev4, LEADSHINE DM 856/870/1182 & 2282, can you confirm?
Wil
Wil
- S14976-ACORN_rev4_LEADSHINE_DM_856,870,1182_&_2282.pdf
- (161.33 KiB) Downloaded 84 times
- dma860e.pdf
- stepper driver
- (738.88 KiB) Downloaded 80 times
