retro fit Laguna/RichAuto
dweber
Post by dweber »
I have a Laguna cnc with hand held controls that I dislike and I want to get to a computer controls again. I know there are a couple other threads about this but I felt there was information that didn't answer all my question. I will give you the information I have and any suggestion you have I will greatly appreciate.
Laguna IQ cnc router 24" x 36" work bed.
3HP Industrial Induction Spindle, liquid cooled, 220V / 30 amp single phase. RPM 6000 - 24000.
Ball Screw all axis.
Leadshine microstep Driver M542-05
Oriental stepping motor type 57BYGH311D-12. (all axis)
Genke BLE17-5F-N1/E Limit switches.
I have been using S14976.DWG wiring diagram.
I will be working on the stepper motors first and this is what I have come up with so far. .
PUL- form the drivers to H2 acorn board to connection ST1. This would follow each stepper motor and continue into H3 acorn board.
DIR- form the drivers to H2 acorn board to connection DR1 This would follow each stepper motor and continue into H3 acorn board.
Because I don't find 5v on the acorn board I would run a jumper wire from the power supply to PUL+ and DIR+.
This process would be for each axis.
I know the wiring diagram doesn't show going to the H2 and H3 but I think that is simpler.
I will work on limit switches next, but I would accept any suggestion if there is a better way of doing this.
This is a ink to my pictures in google. https://photos.google.com/album/AF1QipN ... w5U1Zz3V5I
Thank you in advance for your help.
Re: retro fit Laguna/RichAuto
dweber wrote: Sat Mar 27, 2021 4:55 pm I have a Laguna cnc with hand held controls that I dislike and I want to get to a computer controls again. I know there are a couple other threads about this but I felt there was information that didn't answer all my question. I will give you the information I have and any suggestion you have I will greatly appreciate.
Moved your post here to the Acorn Forum.
Your Photo Album link doesn't work. You need to go to your album and Click SHARE then get the link and post it here. Don't copy it out of the web browser
dweber
Post by dweber »
try it now.
Dave
dweber wrote: Sat Mar 27, 2021 6:33 pm try it now.
Dave
Still not working Dave....
From your Album Page:
Click on the share icon, two lines with 3 dots:
Share Icon.JPG (10.95 KiB) Viewed 5165 times
Then Click on Copy Link:
Copy Link.JPG (8.86 KiB) Viewed 5165 times
Then past it here in your message
That should do it
dweber
Post by dweber »
I did that. I will call a friend that works with google photo and see if he can do something.
Dave
dweber
Post by dweber »
OK give it a try now.
Dave
No luck for me anyway....
dweber
Post by dweber »
don't know what the problem could be. rechecked the settings a dozen times. I will try to repost the link and see if that works.
https://photos.google.com/share/AF1QipN ... IzcDc5WHlR
If this doesn't work I guess I will give up. Thanks for your time.
Dave
dweber wrote: Sat Mar 27, 2021 11:58 pm don't know what the problem could be. rechecked the settings a dozen times. I will try to repost the link and see if that works.
Dave
This link works
Should be no problem getting that conversion done. Standard Leadshine motors.
