Moved this, sorry had it wrong channel before.
I ran the setup wizard to configure a simple control for HUAN YANG VFD as per schematic. The relay board is working fine, I can manually turn VFD on and OFF with the Alt-I inspection screen, but when i try the Spindle start button, the relay will not close, and the Alt-I Status LED in CNC12 stays RED, so I guess i am missing some logic somewhere. The Analog out is changing just fine. What am I missing, I have been searching and watching videos for hours and can't understand what I missed. If mapped SpinFWD and SpinREV to proper relays, shouldn't the virtual control panel be able to toggle the relays when i hit the spindle start button?
Wizard Setup of HY VFD not successful
- report_0035FF8A0FE6-0723203557_2021-02-25_19-09-43.zip
- (607.25 KiB) Downloaded 77 times
- Plasma CNC Controller: Yes
Re: Wizard Setup of HY VFD not successful
Provide a screen shot of your Wizard OUTPUT screen and of your Diagnostic screen please
make SURE you don't have a LINE under the output. That effectively disables the output.
Press Ctrl Alt F to get rid of it if its there.
hello. please update to v4.62, free support for v4.5 has ended.
here is documentation on what marty was suggesting you check.
https://www.centroidcnc.com/centroid_di ... screen.pdf
found here...viewtopic.php?f=60&t=3397
with all Acorn documents..
Yep, had the line under the output. That fixed it. Thanks!
Cool, now upgrade to 4.62...tsoftwerks wrote: ↑Fri Feb 26, 2021 4:01 pm Yep, had the line under the output. That fixed it. Thanks!
My suggestion is to take screen shots of all your Wizard pages.
Then rename the current CNCM directory to CNCM - OLD
Do a fresh install of 4.62
Then hand copy in your machine settings to 4.62. This way you will know you have a fresh install.
You have your old CNCM install if you have to revert back. Just rename the directory back to CNCM
OH, Make a report before you start. Keep a copy of it and your old CNCM directory on a thumb drive.
