I just upgraded from V4.5 to V4.62 but am unclear regarding the auto square set up. I read all of the upgrade notes but it still left me "puzzled". I did not have the option when setting up the inputs in the I?O setup for selecting the slaved motor input sensor to input 2. When viewing the AXIS PAIRING setup screen and notes regarding SLAVED AXIS HOME SWITCH PLC INPUT I was wondering if it was setup automatically so need some clarification.
Thank you for your support
Jr
Question Re: V4.6 (Resolved)
- CNC Control System Serial Number: F045DA798AE4-1119181352
- report_F045DA798AE4-1119181352_2021-02-23_11-23-42.zip
- (602.94 KiB) Downloaded 73 times
Re: Question Re: V4.6
Thank you Keith. After seeing your first post I realized I didn't change the INPUT TYPE from the 'ROUTER' selection to the HOME selection to find the SLAVE HOME INPUT. After looking further into this I found that I should not have moved the settings from the VCP AUX KEY MACRO ASSIGNMENTS from the previous version to V4.62.
Thnaks for the hellp. I should have another cup of coffee to keep me more alert when doing the upgrade
Jr
Jr
Please report back if all is resolved.Jrlee wrote: ↑Tue Feb 23, 2021 3:04 pm Thank you Keith. After seeing your first post I realized I didn't change the INPUT TYPE from the 'ROUTER' selection to the HOME selection to find the SLAVE HOME INPUT. After looking further into this I found that I should not have moved the settings from the VCP AUX KEY MACRO ASSIGNMENTS from the previous version to V4.62.
Jr
Marty all is resolved.
Jr
Jr
