Resetting G28 position with a command?
vw_chuck
CNC Control System Serial Number: 0035FF8FEB5F-0708203490
Post by vw_chuck »
Is there a way to add a line to my G-code so that it updates the G28 location prior to cutting a part?
I don't want to have to remember to go into the centroid program to reset my G28 location when I switch to a new part. I want it to automatically update this location from the G-code when I load it.
Is this possible?
vw_chuck
Re: G number to reset G28 location?
Post by vw_chuck »
I guess I should just ask if there is a G command that will allow me to update the G28 position in Acorn?
There is no G code to do that.
There do not appear to be CNC system variables that access it either.
Since you are looking at customizing your CNC programs anyway, you could use something other than G28 to retract the tool:
- A G0 move referenced to part zero
- A G53 move to specific machine coordinates
- A brief switch to a different WCS (since you can change WCS offsets via system variables)
vw_chuck
Post by vw_chuck »
Hmm that is strange that you can't change this position on the go with a G command. Since the Post Processor references G28 U0W0 throughout the g code then I would have to change every line that references the G28 which is not an option. I would be really nice to be able to simply update the G28 position at the start of the G-code.
Maybe there is an M code that could do this?
Re: Resetting G28 position with a command?
please describe what you (or the post) is trying to accomplish.
what do you mean "switch to a new part"
typically G54-59 is used to "switch to a new part"
is the post written for a shop bot by chance? or a cnc control that doesn't use a work coordinate system?
what are you using to generate the g code? and post a sample of the g code.
vw_chuck
Post by vw_chuck »
I am using Fusion 360 on a cnc lathe.
The problem was I forgot to reset my g28 position and I had it set behind the part at a -z position. When my part was done it attempted to go to the g28 position via the shortest path possible(through my part) if I could reset the g28 position via the g code then I would never run into this issue again.
When I say switched to a new part mean I started making a batch of a different part which requires a different g28 position.
I dont see how using a different coordinate system would change anything.
Instead of using G28 for both axes, you could just end your program -- or go to tool changes -- with:
G0 Z1.0  ; move Z off end of part
G28 U0   ; move X to G28 position
(in whichever order you prefer).
Dave_C
Post by Dave_C »
I'm trying to understand why you would have the G28 position set behind the part?
G28 is usually set to be a return to position or a goto position for a tool change. I've never come across a reason to set it at less than part zero.
Dave C.
Maybe the previous part was shorter?
Dave_C
Post by Dave_C »
That would do it!
Dave C.
