Error in RT-200 Manual wiring diagram?
Page 32 (DC wiring) in the RT-200 manual shows Encoder common (blk/red) connected to pin D of the Amphenol connector. The home switch green wire is also connected to pin D on the Amphenol connector. Is this correct?
Re: Error in RT-200 Manual wiring diagram?
That is correct because the return for the power for the encoder signals should be the same as the return for the power for your inputs.
