Notepad ++ Compile issue (Resolved)
- CNC Control System Serial Number: A900869
Hi Folks, Happy new year
My issue is;
"C:\Users\steph\Desktop\Extron Upgrades\cncm\compile.cmd" "Centroid-Mill-Standard-OAK-ATC-Umbrella-Aly-Tek-r5.src"
Process started (PID=24892) >>>
C:\Program Files\Notepad++>cd \cncm
C:\cncm>mpucomp.exe "Centroid-Mill-Standard-OAK-ATC-Umbrella-Aly-Tek-r5.src" mpu.plc
'mpucomp.exe' is not recognized as an internal or external command,
operable program or batch file.
C:\cncm>pause
I've uninstalled Notepad++ and reinstalled it and I get the same response I've searched in here for answers I've re-read and watched the Youtube Video numerous times and I'm lost
Please help,
TIA
Stephen
My issue is;
C:\cncm>pause
Please help,
TIA
Stephen
Many Thanks
Stephen @ Aly-Tek
Stephen @ Aly-Tek
Re: Notepad ++ Compile issue
Was that a Cmd prompt or a PowerShell prompt? If PowerShell, try using .\mpucomp.exe You can also try the full path to mpucomp and see if that works.
I'm sorry Tom i've no idea what you are talking about All I can say is I press F6 and that's what I get. I followed the Notepad++ Install And TB to the letter. I've checked all the position and symbols in all the areas more than twice. I've doubled checked the zip files for compiling and still nothing
Now it seems I can't even skip this step and load it to trial it as the PLC Installer won't even find the file
Many Thanks
Stephen @ Aly-Tek
Stephen @ Aly-Tek
E415F6F70BC3-0318203049
Suggest you check your C:\cncm folder and see if it actually contains the file called mpucomp.exe as your message could indicate it's missing. If it is missing, you will need to find the location where it is and then as Tom says, you can add its path to your command.
Hope this helps
Hope this helps
Hope this helps
Nigel
Nigel
This message in your output;
indicates that Windows could not find the file mpucomp.exe. As Nigelo says, first confirm that the file exists in the C:\CNCM directory. If not, then you need to locate the file and copy it there. After doing this, if you still get the same error message, try adding a ".\" (without the quotes) in front of the filename in your compile.cmd file like this: .\mpucomp.exe %1 mpu.plc
- CNC Control System Serial Number: 0008DC111213-1202201060
Hello everyone.
I also have some notepad++ compile issue.
anyone have an ide what is wrong? done all in the tech bulletins 294 and seen the video from centroid on youtube but still cant get past this point.
"C:\cncm\compile.cmd" "Centroid-Mill-Standard-OAK-RotaryClamp-r1.src"
; about to start a child process: ""C:\cncm\compile.cmd" "Centroid-Mill-Standard-OAK-RotaryClamp-r1.src""
CreateProcess() failed with error code 2:
The system cannot find the specified file.
================ READY ================
I would guess it cannot find c:\cncm\compile.cmd. Is it in the cncm directory?
yes it is but it was a hidden txt extension on it "compile.cmd.txt" . got it working now. Thanks
See viewtopic.php?f=64&t=4196&p=33895#p33895 to learn how to configure Windows so that it shows you the full name of each file, instead of hiding extensions.
Hello all,
Followed tech bulletin and Centroid CNC Technical Support video and all good
up to the compile command. Here is the error:
"C:\cncm\compile.cmd""acorn_mill_plc.src"
Process started (PID=9428) >>>
'"C:\cncm\compile.cmd""acorn_mill_plc.src"' is not recognized as an internal or external command,
<<< Process finished (PID=9428). (Exit code 1)
Files seem to be in the right directories. Not sure what to fix.
Any help would be appreciated!
