https://cosmos-industrial.com/index.php ... ex&cPath=4
Thanks!
I just bought the one that uses the utility knife. He told me it will cut .500" depth. I can see that it will. I like it a lot.ShawnM wrote: ↑Mon Jun 15, 2020 5:39 pm Very nice. I see the blade offset is 2-12mm, what is the max cutting depth and minimum cut radius of your drag knife? I currently use a Donek drag knife to cut 6mm EVA foam with my CNC. The Donek D2 has a blade offset of 4mm and the max depth of cut of 6mm. I'm cutting 6mm foam so I'm right at the max depth and I'd like a little more cut depth and still keep a small cut radius.
The price is on his website: https://cosmos-industrial.com/index.php ... ucts_id=61
