Windows Firewall (Resolved)
milling
CNC Control System Serial Number: 3859
Post by milling »
Can I turn my windows firewall back on after I have installed CNC12? Directions were a little confusing? Also it seems that if the fiewalls are on the ethernet will not communicate with the acorn?
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: Windows Firewall
Post by Nigelo »
Hope this helps
Nigel
Nigelo
Post by Nigelo »
More specifically, use the forum search facility as I have just done. A search on "Firewall" would have brought up Keith's words of wisdom on the following link
viewtopic.php?f=60&t=3232&hilit=firewall
Hope this helps
Nigel
milling
Post by milling »
thanks
As a point of interest, if you have a CNC PC with all the Windows 10 updates, when you install CNC12 and then start it for the first time, Windows 10 will give you the opportunity to allow CNC12 through the firewall. Simply check the boxes and allow. Then its done.
milling
Post by milling »
ok thanks
