VCP fast/slow jog button does not work
edand19941
CNC Control System Serial Number: C133082-780473490CD2-0710192243
Post by edand19941 »
The fast/slow fog speed on the virtual control panel has quit working after I turned off the smoothing. I have tried several things, but no success. The latest report is attached. What do I need to do to restore the fast/slow jpg toggle?
report_780473490CD2-0710192243_2020-10-14_14-46-17.zip
(921.96 KiB) Downloaded 85 times
Re: VCP fast/slow jog button does not work
If you are stuck in "Slow" mode, it is more likely that your control thinks that a probing device is tripped.
Marc is correct. From your Log file:
(1) 10-14-2020 14:22:59 CNC12 Acorn Mill v4.50
(4) 10-14-2020 14:22:59 9033 Reset Initiated, Press Reset to Clear
(4) 10-14-2020 14:23:29 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 10-14-2020 14:29:46 204 Exiting CNC...Normal Exit (66)
(1) 10-14-2020 14:30:10 199 CNC Started
(4) 10-14-2020 14:30:14 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 10-14-2020 14:30:17 CNC12 Acorn Mill v4.50
(4) 10-14-2020 14:30:17 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 10-14-2020 14:30:18 9033 Reset Initiated, Press Reset to Clear
(4) 10-14-2020 14:30:22 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 10-14-2020 14:30:32 204 Exiting CNC...Normal Exit (66)
(1) 10-14-2020 14:38:42 199 CNC Started
(4) 10-14-2020 14:38:47 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 10-14-2020 14:38:49 CNC12 Acorn Mill v4.50
(4) 10-14-2020 14:38:50 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 10-14-2020 14:38:50 9033 Reset Initiated, Press Reset to Clear
(4) 10-14-2020 14:38:52 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 10-14-2020 14:46:17 Creating report...
