Motors not turning
Harry-O
CNC Control System Serial Number: 6864
Motors not turning
Post by Harry-O »
Upgrading new 4 axis cnc Router old setup died ,Replaced board with Acorn free version. Wired w gheco 203v drivers, 48 volt ps,running 4 960 oz/in stepper motors, dual motors x-axis. Tried to run setup w and w/o siter brd PMDX 134 with x-axis not connected ,no motor s running on y axis or z axis. Also ran Ping test for both computer(supplied by Centroid) and acorn. Report file attached
report_0035FF8FEB4A-0610203400_2020-09-29_12-01-59.zip
(649.6 KiB) Downloaded 123 times
Re: Motors not turning
Do you mean to say that you are able to move the X axis motor (or motors?) through the CNC12 software and Acorn board?
What is a "siter brd"?
Richards
Post by Richards »
The PMDX-134 is not needed with an Acorn. The Acorn controls all signals to the motors. I've used Gecko G203v drivers with my Acorn. I used a DB-25 breakout board to make wiring easy. I did NOT use the Centroid schematic for the G203v. That schematic shows the G203v connected to the screw terminals. I connected DB-25 pin 2 to Step, DB-25 pin 3 to Direction, and DB-25 pin 18 to Common. (Pins 18-25 are all connected to GND, so any of those pins can be used as Common.) I did NOT connect the G203v's Disable pin. If the Disable is connected, the drive will disable the motor. Power, Stepper motor connections, and a current set resistor were all wired according to the G203v manual from Geckodrive.
It's been a while since I tested the G203v, so I don't remember whether I had to invert the signals in the Wizard, or whether I used the normal (non-inverted) setting. In any case, the stepper worked as expected
-Mike Richards
Harry-O
Post by Harry-O »
Richards » Tue Sep 29, 2020 6:34 pm
"The PMDX-134 is not needed with an Acorn. The Acorn controls all signals to the motors. I've used Gecko G203v drivers with my Acorn. I used a DB-25 breakout board to make wiring easy. I did NOT use the Centroid schematic for the G203v. That schematic shows the G203v connected to the screw terminals. I connected DB-25 pin 2 to Step, DB-25 pin 3 to Direction, and DB-25 pin 18 to Common. (Pins 18-25 are all connected to GND, so any of those pins can be used as Common.) I did NOT connect the G203v's Disable pin. If the Disable is connected, the drive will disable the motor. Power, Stepper motor connections, and a current set resistor were all wired according to the G203v manual from Geckodrive.
It's been a while since I tested the G203v, so I don't remember whether I had to invert the signals in the Wizard, or whether I used the normal (non-inverted) setting. In any case, the stepper worked as expected"
Richard I only used PMDX 134 to help save wirering at first , but then went to wire from screw terminals direct to each driver . Still no motor turning, even though dros running on cnc12. I should say that I started this a begining of summer then had to go in for major surgery a month ago with 2 month recovery needed I'm only just starting to get back on my feet. I can only be on feet for about 1 hour a day. All you say about driver disable is correct its not needed I've built 2 other controllers without using it. Tomorow I will go back and rewire motors, I also upgraded to pro version and need to get that done to see if moters finaly turn with motor pairing being used for x axis gantry.I'll post what happens thanks Richard.
Harry-O
Post by Harry-O »
by cnckeith » Tue Sep 29, 2020 4:03 pm
viewtopic.php?f=60&t=2077
search 203v
cnckeith I did attach report but i'm 68 year old tradesman retired Did I do that report correctly ? I'm not the best with computers still learning a lot about subject. my strong point is fabbing machines. Electronics is poor at best but starting to get it .Thanks Keith
post photos of your wiring that would help alot, and screen shots of your wizard settings.
Harry,
Get a DB25 breakout board from Amazon and try and connect them to it. That is what Richard is referring to above with his connections.
Connector Db25 D-sub Male Plug 25-pin Port Terminal Breakout PCB Board
Learn more: https://www.amazon.com/dp/B073RG3GG6/re ... DFbEX2QFBN
Sent from Mail for Windows 10
Richards
Post by Richards »
Here are three photos that show how easy it is to connect a G203V to the Acorn. The top photo shows the G203v and its connections. Starting from the Power Ground connection, White/Blue=Power Ground, Blue= +24VDC, Black=Motor Phase-A, Yellow=Motor /Phase-A, Red=Motor Phase-B, White=Motor /Phase-B, Disable=NOT CONNECTED, Green=Direction, Yellow=Step, Black=Ground, Current limiting resistor, other end of Current limiting resistor.
The DB-25 photo shows Yellow=Pin 2 (Step), Green=Pin 3 (Direction, and Black=Pin 25 (Ground).
The bottom photo shows the G203v, DIN rail mounted terminal blocks for easy configuration, and an Oriental Motors PK268-2AA stepper.
In Wizard, I set the steps to 100,000, pulses per revolution to 2,000 to match the G203v. I used the virtual control panel to test the G203v and motor. It worked, including direction reversal.
(Sorry about all of the shadows. I hope that you can tell the difference between the wires and the shadows. PLEASE be aware that there is NO wire connected to the G203v's disable input. What looks like a black wire is a shadow.)
-Mike Richards
M.R. thanks for that! good stuff.
fyi..here is the "gear we use but don't sell page" with the DB25 breakout boards and other good stuff.
