What is Clearance Angle in Thread Milling
BodeRacing
CNC Control System Serial Number: 102849
Post by BodeRacing »
About to try thread milling. When doing external threads, what is clearance angle? That confuses me.
Re: What is Clearance Angle in Thread Milling
Write a program with two external thread milling cycles.
Make them identical, except put one at X0 with a clearance angle of 0 degrees; and put the other at X2 with a clearance angle of 120 degrees.
For clarity, make the "Depth: Total" a whole multiple of the thread lead.
F8/Graph the program to see what the difference is between the two cycles.
BodeRacing
Thanks!
BodeRacing
It is what I figured it was but is totally clear now. Thanks again!
For a twist, make "Depth: Total" something other than a whole multiple of thread lead.
If you are actually using the Clearance Angle value to avoid obstacles, it is important to know that the lead-out could happen somewhere else.
BodeRacing
cncsnw wrote: Sun Aug 16, 2020 5:53 pm For a twist, make "Depth: Total" something other than a whole multiple of thread lead.
I see exactly what you are talking about!
