Encoder Differential Error
Re: Encoder Differential Error
What I come up with:
Solder drain wire to DB9 shellReminder, for support please follow this post: viewtopic.php?f=20&t=383
When you say the motors have not been run, are they connected so they should run, or are they disconnected?
Have not gotten that far. Will likely do so this week or next.
John
They are actually in the center, one switch for X and one for Y, Centered more or less.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:26 pmIf you have one switch you need to fix it in the CNC12 software configuration. You didn't answer which end of the axis the switch is on so I can't help you there. You will have to either jump the unused limit switch input to COM or use the appropriate limit switch defeat on AIO DCjeingham wrote: ↑Mon Jul 13, 2020 10:24 pm
<SNIP>
Yes, got it, one tripper and software limits, I was sort of aware that would need to be the case.
X switch is in the middle pretty much, Y too. Trips are at either end of the range of travel relative to the single switch.
Will contemplate second switch.
John
Thank you Marty, I should have done some kind of spread sheet myself. Will run it all to ground tomorrow and let you know how it goes.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:59 pm What I come up with:
John
I would move it to one end or the other. BUt it could be used this way, you would have negative and positive values for your soft limits depending on the travel distance either side of the tripper.jeingham wrote: ↑Tue Jul 14, 2020 12:21 pmThey are actually in the center, one switch for X and one for Y, Centered more or less.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:26 pmIf you have one switch you need to fix it in the CNC12 software configuration. You didn't answer which end of the axis the switch is on so I can't help you there. You will have to either jump the unused limit switch input to COM or use the appropriate limit switch defeat on AIO DCjeingham wrote: ↑Mon Jul 13, 2020 10:24 pm
<SNIP>
John
I use spreadsheets and save them.jeingham wrote: ↑Tue Jul 14, 2020 12:25 pmThank you Marty, I should have done some kind of spread sheet myself. Will run it all to ground tomorrow and let you know how it goes.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:59 pm What I come up with:
John
Just double check and see if it jibes....
Jhon
Can you double check your DB9 encoder cabels I think your 5V supply or ground did not go to the enocder .
All three axis has same problem very wired
Mistake in the encoder cabel please double check it
- Swapping A with /A;jeingham wrote:Gotta check tomorrow but it appears that I have the A and /A AND B and /B wire pairs inverted.
- or swapping B with /B;
- or swapping A with B and also /A with /B;
... will not cause differential errors. Doing any one of those things will simply reverse the plus/minus count direction.
Swapping A with B, while leaving /A and /B where they belong -- or vice versa -- will cause differential errors.
If you do not find the connection problem on inspection, then you may want to take the time to make yourself one of these:
http://www.cncsnw.com/EncoderTest.htm
That will tell you exactly where the problem is.
If the motors are not hooked up, the E stop will trigger without showing "EStop", and your error message will be...wait for it...encoder diff error. When the machine tries to move the servos, it looks for an appropriate encoder movement in the correct direction. If there is no motion, or backwards motion, it reads it as an encoder problem and triggers the hidden stop for the machine. Try connecting the motors to see if that prevents the encoder errors.
