Chinese hsd spindle
Re: Chinese hsd spindle
Rosmadi wrote: Wed Apr 29, 2020 8:06 am
martyscncgarage wrote: Mon Apr 27, 2020 11:58 pm I would recommend dry contact relay outputs.
Founded this, ali baba,
Is this suitable,
Instead of providing screenshots, provide links.....
PIcture doesn't do much good without being able to read the specs/info
Rosmadi
CNC Control System Serial Number: 74E1829315CC-0907181194
Post by Rosmadi »
martyscncgarage wrote: Wed Apr 29, 2020 9:26 am
Is this suitable,
Here
https://m.alibaba.com/product/606273081 ... hare%22%7D
Looks right because it shows the inputs with a negative number but you'd better contact them to make sure its NPN
Rosmadi
Post by Rosmadi »
martyscncgarage wrote: Mon May 04, 2020 9:27 am Looks right because it shows the inputs with a negative number but you'd better contact them to make sure its NPN
Thanks marty,, contact has been made, NPN is confirmed,
Rosmadi
Post by Rosmadi »
Hi marty, got the relay board,, which schematic should i follow
Do you have basic electrical/electronic skills?
Very important to be successful and to be able to work your way through the conversion.
Use the Generic VFD wiring as a guide.
You will connect 24VDC from Acorn logic power supply to the COM terminal of that relay board.
You have 8 relays. The older revision Acorn board has two relays on it.
You will take Outputs 3-8 on Acorn to Inputs 3-8 on the relay board.
Rosmadi
Post by Rosmadi »
martyscncgarage wrote: Fri May 15, 2020 1:52 pm Do you have basic electrical/electronic skills?
ok, i guess i have to try it outn
Rosmadi
Post by Rosmadi »
Hi, my output 4 for spindle foward is seem not respone,, can i use output 3 for spindle foward, and how to repair output4 if is damage,, i think i use those ouput4 to power some relay at the first place ,, maybe i made a wrong connection,,
Rosmadi wrote: Sun Jun 07, 2020 10:04 am Hi, my output 4 for spindle foward is seem not respone,, can i use output 3 for spindle foward, and how to repair output4 if is damage,, i think i use those ouput4 to power some relay at the first place ,, maybe i made a wrong connection,,
ALWAYS post a fresh report when asking for help Rosmadi.
Please post pictures of how you wired up the relay.
Post a screen shot of your Wizard input and output screens.
You need to make sure you wired that relay board correctly FIRST.
Rosmadi
Post by Rosmadi »
sorry, here myreport. picture is on the way.. i have use my phone to post it,,is easy that way
report_74E1829315CC-0907181194_2020-06-08_14-37-39.zip
(366.94 KiB) Downloaded 111 times
