mrdttr wrote:As I mentioned in the PM I sent you I've tried every way I can think of to install that update. And I still cannot activate output 13 for spindle direction change. All I ever see is Output 14 for spindle enable. M3, M4 or CW, CCW 13 never lights.
Thanks Mark
I just replied to your PM.
Basically you need to extract the files from the zip and then manually copy them into the cncm directory.
I believe if you update your software to the latest CNC11 software that your problem will then be resolved.
The new PLC program you are running needs the latest software to work correctly.
I just bought this kit 60 days ago shouldn't it have the latese CNC 11 in it? Either way I've tried to download that update and I'm unable to get past the required password & user name. Can you shed any light on that issue for me, I'd be happy to try that latest version.
Please send me an email at tech@ajaxcnc.com and I will reply with the username and password to download the latest software.
Ajax_tech
The latest CNC 11, 3.01 plus the PLC update lee posted seems to have cured my troubles. The spindle bwill reverse and I have a pendant back. On with the shake down opps.
Thanks mrdttr
