Hi ,
I have an acorn board with clear path SDSK motors using free acorn from when I purchased board years back. I can jog XYZ but the DRO does not change stays dashed lines XY and Z. My X axis runs away when I start machine. I have watched video from martyscncgarage about run away motors saying I need to set the PID up for the motor , but also before I do that need to set up home limits right . I can do that until I can get DRO reading . Here is my machine report and pics of system. Thanks Roger
DRO read just dash lines
- CNC Control System Serial Number: C8FD19EB63A3-09180718
- report_C8FD19EB63A3-0309180718_2020-04-04_12-02-41.zip
- (269.98 KiB) Downloaded 80 times
Re: DRO read just dash lines
Press start to home machine.
Thanks for your help found problem clear path motors have a home enable on their tuning screen that I had enabled
