Cutting Undersized (Resolved)
Re: Cutting Undersized
I was working in my barn and found the part.
Clint in NW Arkansas
I worked around my issue (called for "oversize" holes in VCarve), but still have no idea what caused the error.
Have you cut a slow feedrate shallow slot and measured the width that the bit actually cuts in your material? You may be surprised, some solid carbide bits are undersized a bit.
If you cut the holes once climb and then again conventional do the hole sizes change?
Gary - I'll try your suggested tests and report back.
Follow-up. I've been told by the internet that my problem is an issue in the VCarve pocket toolpath (and not the hardware) and was advised to use a profile toolpath. I did and it cut the exact size hole I wanted.
Wow, almost a year...thanks for the follow up!
