Pin terminals or tinned wires
Livnpaintball
Post by Livnpaintball »
What did you guys use to connect to the Acorn, pin terminals on the wires or just tin them? Was also thinking of the RJ45 converters.
Re: Pin terminals or tinned wires
Ferrule connectors on the wires, you could buy this kit for $23 on ebay.
https://www.ebay.com/itm/Ferrule-Crimpi ... 749.l2649
Livnpaintball
Thanks!
Another +1 on ferrules. You have to be very careful on tinning. If the wires wick the solder past where the wire connection is made, you run the risk of fatigue breaking the wire. And, if this happens past where the insulation starts, you now have an intermittent connection that's almost impossible to find.
cbb1962
CNC Control System Serial Number: 38D2695C8301-0122180576
Post by cbb1962 »
tblough wrote: Sun Dec 15, 2019 9:17 am Another +1 on ferrules.
+2
Clint in NW Arkansas
Gary Campbell
Post by Gary Campbell »
Tinned, especially fully tinned is not recommended. That said, I believe tinning is better than nothing, but no where as good as installed ferrules.
Livnpaintball
Gary Campbell wrote: Sun Dec 15, 2019 3:58 pm Tinned, especially fully tinned is not recommended. That said, I believe tinning is better than nothing, but no where as good as installed ferrules.
That is a drawer to be envy of.
Livnpaintball
Guys, I’m getting back to the build, do you like terminal strips or terminal blocks? I’m leaning toward the blocks for power distribution.
Terminal blocks take up less room than strips and ferrules are cheaper than ring or spade terminals.
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
cbb1962 wrote: Sun Dec 15, 2019 1:29 pm
+2
+3 the best way to go no doubt.
