Error 327 on Rapid (Z Axis Move)
thermo44
Re: Error 327 on Rapid (Z Axis Move)
Post by thermo44 »
martyscncgarage wrote: Tue Sep 17, 2019 2:29 pm
Chaz wrote: Tue Sep 17, 2019 2:20 pm I believe this is now solved.
Ran it with the VFD cabinet door open, no fault. Odd. Closed the door, fault.
Checked, VFD error was E.oU.d on the HY unit.
I then remembered that I had set the acceleration time for the VFD from 8 seconds to 3, same as the ramp down.
Anyone who runs a HY VFD knows they have no internal braking and the E.oU.d is often due to overvoltage at ramp down. The door was just luck of the draw. Set the ramp to 6 secs both ways, door closed, no error.
You can specify you want the braking resistor circuit added. Message Huan Yang through Amazon.
When I do use them, I use the GT series, supposedly sensorless vector drive
I have bought the GT series also. 2.2kw. I have a question for you, the VFD has the terminals, I can't add the resistor later? Do I need to ask before buying? Because I already have the VFD same brand. Thanks in advance!
thermo44 wrote: Thu Oct 10, 2019 7:53 am
You get what you pay for. They are too cheap to put the braking resistor circuitry (unless they have recently changed) in the drive. You have to request it. Contact them at service@hy-electrical.com and ask. It makes a day or two for a response.
thermo44
Post by thermo44 »
martyscncgarage wrote: Thu Oct 10, 2019 9:14 am
Thanks Marty! I'll give it a try.
