Allin1DC Homing and Auto lube issues.
Plasma CNC Controller: Yes
Re: Allin1DC Homing and Auto lube issues.
Like Tom said. This should only happen once.
Have you powered down and back up and rehomed? Should not have recurred. If it did, a limit switch would be my first suspect. It's not repeatable. Usually cheap limit switches could do this.
At least your moving forward.....
Deon
CNC Control System Serial Number: AllinOne cncm system ID: 0625181998 / XE3HFDFJBI
Acorn/Leadshine 4axis bench mill: 3403DE6C0783-01919192476
Acorn/Gecko G540 Sherline Lathe: 0479B7B00885-1107192659
Post by Deon »
Ok cool. Because I rebooted and homed again and no message. The only message I get now is at boot up. It has not set up contact technician. I don’t know if that is normal
Deon Daugherty
GOD, Country, Family
Deon wrote: Sun Jun 23, 2019 11:01 am Ok cool. Because I rebooted and homed again and no message. The only message I get now is at boot up. It has not set up contact technician. I don’t know if that is normal
That is normal, until you run the test. My videos go through that.
Make sure you have followed the installation manual to a T. My videos help with that.
You are on your way. Congratulations....
