Software problem
Kutton
Software problem
Post by Kutton »
When I press cycle starts everything is cleared and press cycle start appears again.
https://youtu.be/7TedeUdYK1I
Using Geckodrive G540
Gary Campbell
Re: Software problem
Post by Gary Campbell »
Include a report and screen snips showing your wizard settings. Page 1 for sure. Also include a snip of your IO live (Press Alt + I)
Or simply scroll up on the message box and see what is still triggered
CNC Depot Modular ATC kits
Kutton
Post by Kutton »
Here are photos. Will send backup at a later date when I find it.
report_f045da76bcca-0102191506_2019-04-06_17-33-46.zip
(200.68 KiB) Downloaded 107 times
Gary Campbell
You must have an estop configured. Even if it doesn't exist and is set to NO
Kutton
Post by Kutton »
Ok
Kutton wrote: Sat Apr 06, 2019 10:46 pmOk
Is this machine running or are you still Benchtesting?
Kutton
Post by Kutton »
Machine doesn’t run at this time.
Kutton
Post by Kutton »
Watched and set controller as per Bench Test Running Motor.
Dose estop have to be wired to acorn to make light on G540 to change to green?
No change in software problem.
report_f045da76bcca-0102191506_2019-04-07_11-53-38.zip
(200.19 KiB) Downloaded 99 times
swissi
Post by swissi »
Kutton,
why are you using CNC12 version 4.12 and not the new version 4.14 if you start with a new system?
Your EstopOk is configured as NC (normally closed). So if you don't have an Estop wired the system remains in Estop status. You have to set it to NO if you don't have an Estop wired, otherwise nothing will work.
Also your ProbeDetect signal is configured as NO (normally open) which doesn't make any sense. Remove all probing stuff on your inputs until you have your motors running properly.
-swissi
Kutton
Post by Kutton »
Download new version however wizard did not load.
