Who is up and running on CNC12 4.14?
mick41zxr
Re: Who is up and running on CNC12 4.14?
Post by mick41zxr »
No problems yet on 2 machines, followed the vid & all went smoothly.
One a PM25v clone conversion
Other Scratch built VMC
Michael
mick41zxr wrote: Tue Mar 19, 2019 12:41 am No problems yet on 2 machines, followed the vid & all went smoothly.
Michael
DocsMachine
Post by DocsMachine »
So far it appears mine is up and running under 4.14. 1956 11" Logan lathe conversion:
It's not complete yet- is anything like this every truly complete? :mrgreen: - but it appears to be currently fully functional. Can't say I've given it a really good test yet, as I'm still very much in the "what does this button do, again?" stage of learning how to run a CNC... well anything, really. :D But It's successfuly run several pawns, and I've so far successfully run the first of the Intercon tutorials.
I wish I could be a lot further along at this point, but I have a LOT of other projects in the works these days. :mrgreen:
Doc.
That Logan looks great Doc. Great job on the journey so far....
wallyblackburn
Post by wallyblackburn »
My DIY CNC Router is working fine. Only issue is tool touch off. It isn't clear from the thread if this:
"<cnckeith update>
In-process M6 Tool Change Macros compatible with Acorn CNC12 v4.14"
means that those are updated for v4.14, or if they are going to be updated. Could just try it, just haven't gotten to it yet.
Wally
the macros have been updated for use with v4.14.. "in process" refers to doing tool touch off's in the middle of a G code program.
DICKEYBIRD
Post by DICKEYBIRD »
martyscncgarage wrote: Mon Mar 18, 2019 5:09 pmI chose Leadshine for the drive, and then I went to DB25 and then selected "ENABLE DB25 CUSTOM PIN MAPPING" and it then showed the pins that are reassignable: Could you please double check?
You're correct as usual Marty. I think the reason I wasn't seeing it was that the DB25 menu selection is visible after choosing the Leadshine button but goes away when the button changes to "Custom Leadshine" after manually mapping I/O's using screen shots from the old version. I didn't do a re-install from scratch to verify my assumption but I think that was the issue.
Milton in Collierville, TN
wallyblackburn
cnckeith wrote: Tue Mar 19, 2019 10:05 am the macros have been updated for use with v4.14.. "in process" refers to doing tool touch off's in the middle of a G code program.
Excellent! Thanks!
DICKEYBIRD wrote: Tue Mar 19, 2019 10:37 am
I'm not perfect!😉
But willing to try and recreate things given enough information.
Let us know if you find anything out of the ordinary Milton. You are one of the "seasoned" users. 😁
DICKEYBIRD
martyscncgarage wrote: Tue Mar 19, 2019 11:49 amYou are one of the "seasoned" users. 😁
Hey I like that one Marty. Much better than old & wore out! :lol:
