4.14 slow\fast and inc\contionous buttons not working ( answered)
rangerboy347
CNC Control System Serial Number: 38d2693c4f62-0725181074
Post by rangerboy347 »
when i have my cwp-4 hand wheel on the slow\fast jog and inc\cont buttons do not work. they work if i turn the hand wheel off.
slodat
Re: 4.14 slow\fast and inc\contionous buttons not working
Post by slodat »
I’m noticing similar behavior but I hadn’t sorted out the fix. I’ll try turning off the wireless mpg.
I can't pin point when/what is causing the VCP jog stuff to break. None of the x10, slow/fast, etc work after _____ something.
Gary Campbell
Post by Gary Campbell »
When the pendant is enabled try using the 100/10/1 switch to change speeds. If pendant is ON, pendant does speed, pendant OFF, VCP handles speed
CNC Depot Modular ATC kits
slodat
Post by slodat »
Ahh.. ok. I feel like this is new behavior?
How do I enable/disable wireless MPG?
Gary Campbell
Left Rotator switch. ………….. to Off. Watch the MPG LED on the VCP
JoeG
CNC Control System Serial Number: 1119181353
Post by JoeG »
Just set the axis switch to off.
The VCP buttons work as expected then, you have to do this before you turn off the pendant.
JoeG
rangerboy347
the 1/10/100 change that works fine now stuck in turtle mode before i could power of pendant and use touch screen and turn pendant back on and it would be in whatever you had it on the screen. i will have to check on my mill i haven't updated it but i'm pretty sure i had no issues switching to turtle to rabbit. I'll wait for all the bugs to get sorted.
joe
The mpg takes priority over the VCP for fast and slow, think of it this way if MPG is set on x100 or x10 and you go change the turtle and rabbit button on the VCP to the turtle how would the mpg know that you have switched to slow? ( Maybe the MPG knob could auto-magically rotate to x1?:))
Switch the mpg from x100, x10 to x1 (or rotate the other knob to the off position) and observe the VCP fast slow incr buttons.
rangerboy347
Re: 4.14 slow\fast and inc\contionous buttons not working ( answered)
so 1X is incremental and 10x is turtle and 100x is rabbit basically in the new update.
rangerboy347 wrote: Tue Mar 19, 2019 4:00 pm so 1X is incremental and 10x is turtle and 100x is rabbit basically in the new update.
yes
