452_PC Receive Data Error
- CNC Control System Serial Number: c19288
Re: 452_PC Receive Data Error
I believe the voltage at the transformer was 115v and at the Cap was 150 volts. Is this too much?
I need Primary voltage ??? means input voltage and secondary voltage output ???
You can use the existing transformer if you provide me the full information
It is a GE # 9T51B0011 1.5Kva
Primary 240v
Secondary 120v
Primary 240v
Secondary 120v
You can use the existing GE # 9T51B0011 1.5Kva ..........by simply provide the 110 or 120 AC to the primary and output then must be 60AV after the cap and bridge around 85~90 VDC .......which will result in slightly less rapid ...but you may safe some 100 bucks
Does anyone know of a reasonably priced transformer that is regularly available that would put out 90-95volts?
AJax has a complete kit for the powersupply
"220VAC Power Supply Kit
For those of you with larger machines, or larger motors, this power supply is for you. The kit includes a 220VAC transformer, high power capacitor, and bridge rectifier. This power supply can drive up to (4) 40in-lb servos.
220VAC Servo Motor Power Supply Kit $705"
Better you may ask for the transformer separately ....
tech@ajaxcnc.com
tech@ajaxcnc.com
Are there any other transformer options other than ajax available that are more reasonably priced?
