Apart from a Shapeoko router, which I have about an hour's total actual time on, my converted Logan lathe is the first functional CNC I've ever used. Prior to these, I'd rarely even been in the same room as a CNC... well, anything. I'm not a complete dolt- no matter what my mother says
But I'm still very green on the actual use and application, that is, pretty much everything from tool offsets to even just loading new programs into the system. (I don't even have any new programs. I haven't gotten that far yet.
As such, considering I have pretty much zero options for local mentoring (I may have the only Acorn in the entire state of Alaska) I need to lean on some of you fellows to answer my stupid questions. And I'm sure most of them will be stupid, but as they say, the most stupid question is the one you didn't ask.
To start with, I have a first-gen Acorn, currently running version 4.12, with a wireless MPG, feeding two Automation Technologies "hybrid servo" motors with encoders. The encoders only feed back to the drivers, not the controller, and basically just watch for slippage/missed steps. (They fault out and stop if that happens.)
I recently upgraded to 4.12 to activate my MPG, and after a minor glitch or two, it's working as it should, barring an ongoing issue being discussed in another thread.
I just spent this afternoon, as I was digesting my way to more pie and maybe some more German mashed potatoes, setting up the first four tools in the tool offset library. I happened to have some of the tools already listed by default in the CNC12 software, so I just set the offsets for four of the first five or so (55 degree diamond, 80 degree diamond, .125 parting blade, and OD threading tool.)
I then set up a chunk of 1" bar in the chuck, hoping to turn another pawn, and set the work offsets.
I thought I had at least the minimum amount of information for the lathe to make the pawn- I've done one before- but when I press cycle start, the carriage zooms off to the right, hits the limit switch, and cancels the job.
So, first stupid question: What should the machine do when you start the pawn?
I assumed that, as it'd already been homed, and the tool offsets set, that it would have started the spindle (it didn't) and started moving the tool into position. When I saw it heading to the right, not the left, I assumed it'd home itself, then go find the workpiece, but it didn't do that either.
Sorry, I just simply don't have enough experience yet to know what it should or should not be doing, and that makes it very hard to know what needs to be fixed or adjusted.
Doc.
