Rigid Tapping instructions and setup info for Mill or Lathe
Rigid tapping - Mill Intercon
Please see Acorn Rigid Tapping setup guide attached.
Acorn Rigid Tapping Setup for Mill and Lathe.pdf
(213.73 KiB) Downloaded 6 times
(213.73 KiB) Downloaded 591 times
ScotY
Re: Rigid Tapping on Mill or Lathe
Post by ScotY »
I was looking at the v4.10 release notes and I didn’t see anything (I think) that would be detrimental for me to go backward to v4.08. I have Mill Pro and am only experimenting with Intercon and rigid tapping. Can I just use the v4.10 update procedure and go back to v4.08 until the new, fixed CNC12 is released?
scot, let have a TV session today and i'll fix the issue. K
ScotY
Re: Rigid Tapping instructions and setup info for Mill or Lathe
Post by ScotY »
Thanks again for the help, Keith! Rigid tapping is operational here!
DICKEYBIRD
Post by DICKEYBIRD »
Great stuff Scot, glad you have it going your way! :D
I'm very interested in the thread milling process for the mill I'm building. I hope someone posts a video showing how it's done using Acorn/CNC12/Intercon.
Milton in Collierville, TN
ScotY
Post by ScotY »
Hi Milton,
Thanks, it is really cool how rigid tapping works! I hope to also try thread milling at some point.
