Problem testing my set up.
Terry1956
Post by Terry1956 »
Hi. I am at the point of making that first test part on my lathe. At the moment I only have the free version of centroid turn. I know that the pawn is the test part. However it looks like when I load the pawn g-code it is only set for imperial not metric. I made gcode for a very small part myself but when I try to machine the software stops loading at line 19.
So is there a way I can reset the pawn to metric, and is the gcode not loading after line 19 down to it being a free copy of the software. Thanks.
Re: Problem testing my set up.
Yes there should be a metric folder in \ncfiles with a metric pawn.
I have attached the file.
PAWN-MM.cnc
(2.37 KiB) Downloaded 13 times
Terry1956
Post by Terry1956 »
Thanks for that. Michael
Terry1956
Post by Terry1956 »
Hi Awe, I tried the software, however it all went wrong. I started by moving both axis near the end of their travel and setting home. I then moved the tool to the leading edge of the material and set the z axis to zero and the x axis to the diameter of the material. However on starting the job the tool just moved in the x+ direct until near the end of travel and I had to stop the job. What am I doing wrong. Thanks
CentroidFrog
Tech Support
Post by CentroidFrog »
Please post a fresh report.
Here is how:
Also, which job were you running?
The MM pawn?
Sorry, I send you an old version with a bug in it.
That was with G20 not G21
Try this repaired one pls.
PAWN-MM.cnc
The Pawn should look like this in Graph Job on a metric lathe
Terry1956
Post by Terry1956 »
Thanks, will try it out later today.
Black Forest
Post by Black Forest »
Please don't refer to Uwe(suntravel) as Awe. His head is big enough without being in Awe of him. :lol:
Sir Uwe is acceptable.
Terry1956
Post by Terry1956 »
lol, predicted text.
